SD card format on Windows 7
Guys,
whats the best (working) way to format a SD card for the Cobra?
I tried regular windows format and also the SD Formatter of Panasonic, but I get filesystem not formatted errors on the Cobra.
You can format it on the PC as FAT32.
You shouldn’t so if you do we need to double check few things…you can start by adding a 10uF or more capacitor right on the power source of the SD card.
Well, I was not eager to start soldering on the Cobra, and went out to buy a new SD card…tada, worked from the first time. Thanks anyway.
Eric
