I currently use a SanDisk Ultra 4GB SD Card (class 4 - up to 15 MB/s) for my application and it works fine. I recently tried to use a SanDisk Ultra 8 GB SD Card (class 6 - up to 20 MB/s) and the application now fails every time with the following error. I tried another 8 GB class SD card by Wintec and it worked fine. Would it be due to the high speed rating of the SanDisk Ultra 8 GB SD card? This is a production application so I was just trying to go with the highest possible quality (and quickest) SD card without breaking the bank.
#### Exception System.Exception - 0xffffffff (1) ####
#### Message:
#### GHIElectronics.NETMF.IO.PersistentStorage::.ctor [IP: 0000] ####
#### SPSMicro2.CoreLib.SPSMicroApp::MountFileSystem [IP: 000e] ####
#### SPSMicro2.CoreLib.SPSMicroApp::Initialize [IP: 002d] ####
#### SPSMicro2.MicroUI.Program::Main [IP: 0039] ####
A first chance exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.IO.dll
The program ‘[6] Micro Framework application: Managed’ has exited with code 0 (0x0).
