Schrödinger's null. Strange behavior of a just initialized null elements from a string array
I came across the fact that an array of strings initialized with “null” elements when checking an element for “null” can return FALSE depending on the syntax of the code.
For example:
new string[] { null }[0] == null
as well as
new string[] { null }[0] is null
will return False
But:
new string[] { null }[0] == null ? true : false
as well as
new string[] { null }[0] is null ? true : false
will return True
When creating a string array in the debugger, we may see "" (empty) values when they should be null.
When you explicitly set the value null for an element after creating an array, this uncertainty disappears and the debugger displays a null value. And the comparison also works correctly.
If this behavior is not a bug, then please write about this feature in the documentation.
Code:
using System.Diagnostics;
namespace ArrayString
    internal class Program
        static void Main()
            string[] snArr = new string[] { null };
            string[] seArr = new string[] { string.Empty };
            Check(nameof(snArr) + "[0]", snArr[0]);
            snArr[0] = null;
            snArr[0] = string.Empty;
            Check(nameof(seArr) + "[0]", seArr[0]);
            seArr[0] = null;
            seArr[0] = string.Empty;
        private static void Write(string msg)              => Debug.WriteLine(msg);
        private static void Write(string msg, bool isNull) => Write($"{$"\"{msg}\"",-40} {isNull}");
        private static void Check(string valueName, string obj)
            Write($"{valueName} == null",                obj == null);
            Write($"{valueName} is null",                obj is null);
            Write($"{valueName} == null ? true : false", obj == null ? true : false);
            Write($"{valueName} is null ? true : false", obj is null ? true : false);
            Write("");
Could you please add to githib issue so we don’t forget it?
OK, ready.
This is easy to explain. A variable is both null and not null until you unbox it.
I came to the same conclusion, colleague!
Not fixed in v3.0.0.2000-prerelease.
Please note this bug. The behavior of creating an uninitialized or NULL-initialized string array is illogical.
Yes, this issue has not been fixed because the cost of addressing it outweighs the benefit.
How much of an inconvenience is this for you?
I can’t say I encounter it every day, week, or month. No. But once every six months, when I’ve forgotten this detail, I stumble over it.
If it’s not worth the effort, then please just add it to the list of Limitations.
