SC13048 CAN Bus
I am trying to get CAN-Bus running on FEZ-Pico Can1 using the sample code but get a lot of System.NotSupportedExceptions when accessing the Filter methods and/or Enable method.
The same code works well on FEZ-Stick / Dev.board (using Can2).
Hardware is the same (FEZ + SN65HVD230) and USB-CAN-Adapter on the PC-side.
Any idea is welcome!
Regards, Juergen
FEZ stick uses SC20xxx support CANFD
FEZ pico uses SC13xx does not support CANFD.
Show us your code so we know what wrong there. First check should remove “SetDataBitTiming” which is not supported on SC13xxx
Haven’t found another way to upload…
// Project:       TCLR_CAN_Test
// File:          Program.cs
// Created:       2024-08-22
// Author:        JBranscheid
// Updated:       2024-08-22
// (c) 2024 Branscheid Industrie Automation GmbH - All rights reserved.
using System.Diagnostics;
using GHIElectronics.TinyCLR.Devices.Can;
namespace TCLR_CAN_Test
    internal class Program
        private static void Main()
            Debug.WriteLine("TCLR_CAN_Test started..");
            // var can = CanController.FromName(SC20100.CanBus.Can2);   // FEZ-Stick
            var can = CanController.FromName(SC13048.CanBus.Can1);      // FEZ-Pico
            var propagationPhase1 = 13;
            var phase2 = 2;
            var baudratePrescaler = 6;
            var synchronizationJumpWidth = 1;
            var useMultiBitSampling = false;
            can.SetNominalBitTiming(new CanBitTiming(propagationPhase1, phase2, baudratePrescaler,
                // ReSharper disable once ConditionIsAlwaysTrueOrFalse
                synchronizationJumpWidth, useMultiBitSampling));
            var message = new CanMessage()
                Data = new byte[] { 0x48, 0x65, 0x6C, 0x6C, 0x6F, 0x2E, 0x20, 0x20 },
                ArbitrationId = 0x12,
                Length = 8,
                RemoteTransmissionRequest = false,
                ExtendedId = false,
                FdCan = false,
                BitRateSwitch = false
            byte cntr = 0;
            //The following filter will accept arbitration IDs from 0x12 to 0x20 inclusive.
            can.Filter.AddRangeFilter(Filter.IdType.Standard, 0x12, 0x20);
            //The following filter will accept arbitration IDs from 0x500 to 0x1000 inclusive.
            can.Filter.AddRangeFilter(Filter.IdType.Standard, 0x500, 0x1000);
            //The following filter will accept arbitration IDs of 0x11 and 0x13.
            can.Filter.AddMaskFilter(Filter.IdType.Standard, 0x11, 0xFD);
            //The following filter will accept arbitration IDs of 5678 only.
            can.Filter.AddMaskFilter(Filter.IdType.Standard, 0x5678, 0xFFFF);
            can.MessageReceived += Can_MessageReceived;
            can.ErrorReceived += Can_ErrorReceived;
            can.Enable();
                message.Data[7] = cntr++;
                can.WriteMessage(message);
                Thread.Sleep(100);
        private static void Can_MessageReceived(CanController sender, MessageReceivedEventArgs e)
            sender.ReadMessage(out var message);
            Debug.WriteLine("Arbitration ID: 0x" + message.ArbitrationId.ToString("X8"));
            Debug.WriteLine("Is extended ID: " + message.ExtendedId.ToString());
            Debug.WriteLine("Is remote transmission request: "
                            + message.RemoteTransmissionRequest.ToString());
            Debug.WriteLine("Time stamp: " + message.Timestamp.ToString());
            var data = "";
            for (var i = 0; i < message.Length; i++) data += Convert.ToChar(message.Data[i]);
            Debug.WriteLine("Data: " + data);
        private static void Can_ErrorReceived(CanController sender, ErrorReceivedEventArgs e)
            => Debug.WriteLine("Error " + e.Error.ToString());
SC13xxx also doesn’t support AddRange filter, remove it.
I tried that before by commenting out all ‘Filter’ calls.
Some result, can.Enable() throws an NotSupportedException.
I just ran on my SC13xxx dev board, no problem on v2.3.0.1000
Below is setup for 500Kb.
On Pico there is no CAN hardware but it should not say “NotSupportedException” if you you run my code below.
static void Main()
    can.SetNominalBitTiming(new GHIElectronics.TinyCLR.Devices.Can.CanBitTiming(5, 4, 8, 1, false)); // 500Kb at 40MHz
    var counter = 0;
    can.Enable();
        Thread.Sleep(1000);
        Debug.WriteLine("CAN Enabled " + counter++);
    var data = "";
I tried your example and it enables the CAN. But when sending first message, it throws an exception:
The thread ‘’ (2) has exited with code 0 (0x0).
TCLR_CAN_Test started…
#### Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (1) ####
#### Message:
#### GHIElectronics.TinyCLR.Devices.Can.Provider.CanControllerApiWrapper::WriteMessages [IP: 0000] ####
#### GHIElectronics.TinyCLR.Devices.Can.CanController::WriteMessages [IP: 001c] ####
#### GHIElectronics.TinyCLR.Devices.Can.CanController::WriteMessage [IP: 000e] ####
#### TCLR_CAN_Test.Program::Main [IP: 0143] ####
Exception thrown: ‘System.InvalidOperationException’ in GHIElectronics.TinyCLR.Devices.Can.dll
Same code works on SC20100 (FEZ-Stick) using the same Hardware (.SN65HVD230).
Regards JBranscheid
My code:
            GpioPin ldrButton;
            CanController can;
            int baudratePrescaler;
            if (true)
                // FEZ-Pico
                baudratePrescaler = 8;         // 16 = 250k, 8 = 500k for SC13048
                ldrButton = GpioController.GetDefault().OpenPin(SC13048.GpioPin.PC13);
                // FEZ-Stick
                baudratePrescaler = 6;         // 12 = 250k, 6 = 500k for SC20100
                ldrButton = GpioController.GetDefault().OpenPin(SC20100.GpioPin.PE3);
            ldrButton.SetDriveMode(GpioPinDriveMode.InputPullUp);
            var phase2 = 2;
                ArbitrationId = 0x16,
                Length = 8,
                ExtendedId = false,
                FdCan = false,
                BitRateSwitch = false,
                Timestamp = DateTime.Now
            byte cntr = 0;
            can.Filter.AddMaskFilter(Filter.IdType.Standard, 0x10, 0xFF);
            can.Enable();
                try
                    if (ldrButton.Read() == GpioPinValue.Low)
                catch (Exception e)
                    Debug.WriteLine(e.Message);
                Thread.Sleep(100);
        // <summary>
        // Can message received.
        // </summary>
        // <param name="sender">    The sender. </param>
        // <param name="e">         Message received event information. </param>
            Debug.WriteLine("Length: " + message.Length.ToString());
            var data = BitConverter.ToString(message.Data);
        // <summary>
        // Can error received.
        // </summary>
        // <param name="e">         Error received event information. </param>
It doesn’t work because you are setting wrong speed.
As I see FEZ Stick set for 500Kb, mean SN65HVD23 set 500Kb.
But FEZ Pico you are setting 312.5Kb. One side is 500Kb and other side is 312.5Kb of course not work :slight_smile:
Change to below to get 500Kb on pico.
 var propagationPhase1 = 5; // GHI changed to 5, it was 13
 var phase2 = 4; // GHI changed to 4, it was 2
Thank you, works so far.
But, …where do I get this magic numbers for the SC13048?
Not magic numbers. Our docs explains it. But if you want shorter, here it is.
SC13 CAN clock 40MHz.
Prescal = 8.
40 / 8 = 5MHz
  • to get 500Kb = 0.5Mhz
5/ 0.5 = 10.
10 is (T1 + T2 + 1)
I set T1 = 5,
T2 = 4
=> 5 + 4 + 1 = 10.
  • To get 250Kb = 0.25MHz
5/0.25 = 20 = (T1+ T2 + 1)
so you can set T1 = 10, T2 = 9 => T1 + T2 + 1 = 10 + 9 + 1 = 20…
Same for SC20xxx but SC2xx Clock is 48MHz.
But T1 or T2 can not be zero or too large (32, 64 or 128 max), I don’t remember exactly, depend on the device. At that time you need to adjust prescaler.
