Can you explain what the pros and cons of MicroPython vs C# for embedded applications might be? I’m just getting barely competent with C# but many of the scientists where I work are Python enthusiasts.
Hello, hendra! This is awesome! I’ve just started use BrainPad with micropython, and your examples pretty useful for me. Did you use built in function pwm, for driving buzzer or leds? I get error when try run it.
thanks duma_v, glad you can use it. I still trying the pwm module, it seems the PWM module for the board are still inside the timer library. the buzzer and servo so far not working with micropython. Still trying to test a few things for those
I have added new code to run flappy bird on the BrainPad using micropython. the code was based from here. I have modified a little so it can run on the BrainPad.
