I want to run these three modules together (I have quite some ram free so its not going to be an issue).
the problem is that both FEZ connect and FEZ music shield are initialized on on same SPI module in examples.
another thing is that in the provided example the includes
using GHIElectronics.NETMF.FEZ.Shields;
are not found , neither IO nor Shields.
I have references added as I am already using the same solution for touch and connect.
another this I would like to ask is that in
Resources.GetBytes(Resources.BinaryResources.song);
GetBytes() is not a member of Resources and Resources.BinaryResources is also not showing up
I have spent the night toying around with the stuff and was amazed by how fast I could make prototypes
If I am doing something wrong kindly tell me.
I have a lot of experience with C#, C++ and some other languages and I also have a good amount of experience with electronics.
I have the latest SDK 4.2 installed and am using the FEZ panda II template so yes my project is set on 4.1
Regards,
Shehroze Malik.
