I want to connect a Spider to the Insteon PowerLinc Modem (2413S). Since I have zero knowledge of how I would go about this, I’m hoping for a possible solution.
The idea I have is to use the RS232 module, but I’m not sure if I need a Female/Female RS232 crossover or a straight cable.
I’m assuming I would be able to connect to the serial port from the spider using something like new SerialPort(“COM1”), but I’m not sure if that’s right either.
Would it be (“COM1”) or (“UART0”)?
In the end I will hopefully be able to communicate with the PowerLink using FluentDwelling(http://soapboxautomation.com/products/fluentdwelling/). I’m sure this seems like overkill, but I don’t trust my pc to stay on all the time and I have other ideas for the spider, so I thought running everything from one place might be fun to try.
In case I wasn’t clear,
- do i need a crossover or straight cable to communicate between the RS232 module and the modem(just another device http://www.insteon.net/pdf/2413Sqs.pdf)
- to send/receive commands via RS232 module, do i use UART0 or COM1 as the serial port name? SerialPort UART = new SerialPort(NameOfPort, BaudRate)
any other tips/suggestions would be great.
thanks,
nick
