Not a major concern right now, but I’m looking ahead.
I have my RPi2, and I just got the wifi dongle. In debug mode I can run the default app to setup wifi, and then I can start debugging my Cream app, which uses the setting established by the default app.
That’s fine while this is sitting on my desk, but does anyone have some insight into how this would be accomplished with a deployed app? Is there code to configure wifi from within a startup app?
You forgot to tell us which OS you are using. Win10 or Linux?
Either way, the answer is ‘yes’. The most common onboarding procedure is to put your Wifi into AP mode with a recognizable SSID (random prefix, well-known suffix, for instance). Your setup program can search for that SSID and provide a configuration interface either through a REST api or web interface. Once configured, the RPI can drop the AP mode and go into client mode and connect to your wifi infrastructure.
Similar mechanisms are used by ChromeCast and the AllJoyn Onboarding Service. Variations on the theme usually involve more automation and/or security infrastructure.
@ Squeebee - Well, I’ve got it (the new 7") running for raspian, works nice. Resolution Is only 800*480. Applied the obligatory update/upgrade, did a poweroff and inserted the win-iot only to find out it is and stays … black … :wall:
@ Andre - It was mentioned that win-iot would pick up the display as just another HDMI, so no, didn’t change it, but the thought has crossed my mind too. Already had to change it to enforce HDMI.
