Hello Experts,
Anyone know of good code to drive the mini robot with say… couple distance sensors? I can crack my head and try to “re-invent the wheel”… come up with the logic for it but It will make me loose more hair, and I bet it will still be buggy.
Thank You!
Always use baby steps…first, were you able to more the robot? rotate? go backwards?
Yes,
I am able to move robot, read signal from reflective sensor and act acordingly like backing up, etc.
Thanks!
namespace FEZ_Mini_DEMO
static FEZ_Components.DistanceDetector myRanger = new FEZ_Components.DistanceDetector(FEZ_Pin.AnalogIn.An1, FEZ_Components.DistanceDetector.SharpSensorType.GP2D120);
static FEZ_Components.ReflectiveSensor InputPortA6 = new FEZ_Components.ReflectiveSensor(FEZ_Pin.AnalogIn.An6, 10);
static FEZ_Components.ReflectiveSensor InputPortA7 = new FEZ_Components.ReflectiveSensor(FEZ_Pin.AnalogIn.An7, 10);
static FEZ_Components.ServoMotor myServo = new FEZ_Components.ServoMotor(FEZ_Pin.Digital.Di8);
FEZ_Components.LED OnBoardLED = new FEZ_Components.LED(FEZ_Pin.Digital.LED);
OnBoardLED.StartBlinking(100, 500);
for (int i = 1000; i < 10000; i += 100)
FEZMini_Robot.Beep(i, 10);
while (true){
if ((byte)InputPortA6.GetState()==1 || (byte)InputPortA7.GetState()==1)
FEZMini_Robot.MoveRamp(-40, -40, 0);//backing up a little
FEZMini_Robot.MoveRamp(-60, 10, 0); //turn around
FEZMini_Robot.MoveRamp(0, 0, 0);
FEZMini_Robot.Beep(6000, 300); //make some noise
Thread.Sleep(500);
Thread.Sleep(500);
FEZMini_Robot.MoveRamp(50, 50, 0); //Left +, Right +
