Using the latest version of the Wifly module, I ran into this problem.
In case I deliberately force an exception via a wrong argument value of method wifi_RN171.EnableDhcp();
Running the code the exception is not handled as I expected, i.e. the catch clause code is not executed.
Using the debugger the throw is reported by the debugger. Possibly a matter of :wall:
wifi_RN171 = new GTM.GHIElectronics.WiFiRN171(1);
try
wifi_RN171.EnableDhcp("", "255.255.255.000", "192.168.0.1");
catch (ErrorReceivedException ex ) {
debug.print("Exception");
@ freeck - I do not have the code for the library in front of me, but based on the code snippet you provided there is no reason to believe that an ArgumentNullException should be thrown, none of the arguments you are passing are null.
sorry I put you on the wrong track, the exception came from another source.
I changed the example above with a different exception, and still I do not reach the catch clause…
A standard exception like a “devidebyzero” behaves as expected…
@ freeck - The driver should not be throwing an exception in event handlers. It should raise an event instead. Sadly, since the module is discontinued, it is unlikely we will be able to rework the driver that much.
Well, I intentionally used a wrong argument to force and test the exception mechanism…
Using exceptions in rare cases is very elegant! So i will try to modify the code to generate exceptions that can be caught on the application level.
@ RoSchmi - I know you are… I read al your posts concerning this module. I have got library 4.2 working. but when I looked at the latest version 4.3 it seemed the code was better than the previous versions. But unfortunately this seems to be not always the case. Still i would like to use the latest version as a starting point for further modifications. I am looking for a way to extend this library with new methods as separate extensions, and not develope and maintain a complete new modified wifly-library.
perhaps using partial classes is a way to do so, but I am a medior C# programmer , perhaps the are better ways to do so.
Has GHI some recommendations concerning this.
I am more that happy to start a new topic on this issue and see how to continue…
