Does anyone have an example of UART in RLP on 4.3? I’m looking to run this on G120 (assuming it is faster?).
Cheers
Cheers
There is a RLP sample on RS485, but this is identical for the uart part.
[url]https://www.ghielectronics.com/community/codeshare/entry/219[/url]
OK, thanks. My knowledge of C is limited so I will have to study the example carefully.
That is over 4 years old as well, so I’ll have to work out if any of the RLP implementation (on the native side) has changed.
Still, every day’s a school day! :think:
Does anyone know where I can find the relevant header files for UART on a G120? The link in that codeshare entry does not work.
Cheers
Edit; this one? https://www.lpcware.com/content/nxpfile/mcb1700-sample-code-bundle-lpc17xx-peripherals-using-keils-mdk-arm
LPC17xx should be good, G120 is LPC1788.
I have a few questions about the RS-485 example, if anyone has five minutes over a coffee to look at it? I’d be really grateful.
Thanks in advance.
@ cyberh0me - good questions!
You’re right that netmf is not the best option. This is mostly a learning exercise. I’d like to eventually move over to C/C++ and RLP seems to be a good taster and if I can do something faster too then that’s a bonus.
In case anyone is interested, this is the native code I’ve currently have working on a G120, also using the memory allocation trick that John(GHI) showed me recently (I haven’t tested the performance yet);
#define G120
#include "RLP.h"
#include "type.h"
#include "uart.h"
#include "lpc17xx.h"
#include "stdbool.h"
/* UART definitions for UART 0 (COM1 in NETMF) */
#define UART_IER LPC_UART0->IER
#define UART_IIR LPC_UART0->IIR
#define UART_LSR LPC_UART0->LSR
#define UART_THR LPC_UART0->THR
#define UART_RBR LPC_UART0->RBR
#define UART_FCR LPC_UART0->FCR
#define UART_INT UART0_IRQn
void* ptr;
uint8_t* data;
uint8_t* length;
/* Interrupt Handler
void InterruptHandler(void * arg)
uint8_t LSRValue;
uint8_t IIRValue = UART_IIR;
IIRValue >>= 1; /* Skip pending bit in IIR */
IIRValue &= 0x07; /* Check bit 1~3, interrupt identification */
if (IIRValue == IIR_THRE) /* THRE, transmit holding register empty */
LSRValue = UART_LSR; /* Check status in the LSR to see if valid data in U2THR or not */
/* Initialise the driver.
bool HCD_Init()
if (RLP->magic != RLP_EXT_MAGIC)
return false;
RLP->Interrupt.Uninstall(UART_INT);
UART_IER = IER_THRE; /* Enable UART2 interrupt */
UART_FCR = 0x00; /* Disable FIFO */
/* Install interrupt handler */
if (!RLP->Interrupt.Install(UART_INT, InterruptHandler, NULL))
return false;
return true;
/* Deinitialise the driver.
void HCD_Deinit()
/* Clear FIFO.
void HCD_ClearFifo()
volatile uint8_t data;
while (UART_LSR & LSR_RDR)
data = UART_RBR;
/* Send a single byte over the UART port
void HCD_SendByte(uint8_t data)
unsigned int status = RLP->Interrupt.IsGlobalInterruptEnabled();
if (status > 0) RLP->Interrupt.GlobalInterruptDisable();
UART_THR = data;
if (status > 0) RLP->Interrupt.GlobalInterruptEnable();
while (!(UART_LSR & LSR_TEMT));
RLP->Delay(50);
/* called from managed code.
int InitCOM1(void** args)
return HCD_Init();
int DeinitCOM1(void** args)
HCD_Deinit();
return 1;
/* sends the bytes from the data buffer, one at a time
int SendDataCOM1(void** args)
uint8_t i;
for (i = 0; i < *length; i++)
HCD_SendByte(data[i]);
return (int)i;
/* initialises memory space to hold the data buffer
int InitCOMbuff(void** args) {
ptr = RLP->malloc(64 + 1);
if (!ptr)
return 0;
data = (uint8_t*)(ptr + 0);
length = (uint8_t*)(ptr + 64);
return (int)ptr;
/* uninitialises memory space to hold the data buffer
int UninitCOMbuff(void** args) {
RLP->free(ptr);
return 0;
And some simple managed code to test it with;
SerialPort serialPort = new SerialPort("COM1", 9600, Parity.None, 8, StopBits.One);
serialPort.Open();
var image = new RuntimeLoadableProcedures.ElfImage(Resources.GetBytes(Resources.BinaryResources.TemplateG120_43));
var init = image.FindFunction("InitCOM1");
var result = init.Invoke();
Debug.Print("InitCOM1 returned: " + result.ToString());
var initCOMbuffer = image.FindFunction("InitCOMbuff");
var bufferAddress = (uint)initCOMbuffer.Invoke();
Debug.Print("InitCOMbuff returned: " + bufferAddress.ToString());
if (bufferAddress == 0)
throw new OutOfMemoryException();
var byteArray = new byte[65];
var toSend = "Man United are the best!! :-D";
Encoding.UTF8.GetBytes(toSend, 0, toSend.Length, byteArray, 0);
byteArray[64] = (byte)toSend.Length;
AddressSpace.Write(bufferAddress, byteArray);
var sendData = image.FindFunction("SendDataCOM1");
result = sendData.Invoke();
Debug.Print("SendDataCOM1 returned: " + result.ToString());
var deinit = image.FindFunction("DeinitCOM1");
result = deinit.Invoke();
Debug.Print("DeinitCOM1 returned: " + result.ToString());
var uninitCOMbuff = image.FindFunction("UninitCOMbuff");
result = uninitCOMbuff.Invoke();
Debug.Print("UninitCOMbuff returned: " + result.ToString());
serialPort.Close();
