I am working with RLP on a Panda II to read a DHT11 sensor because it uses a custom protocol.
Everything works fine, after a lot of time, but a few questions about RLP are still there:
Why is it required to unlock the RLP feature with my personal account ?
Is it supported to load more ELF-Files or is it only possible to load a single ELF-File which must contain all requried procedures?
Will the loaded ELF file unloaded automatically at atny time? Is it possible to unload these files manually?
How long is the RLP feature active after it has been enabled? Is it until the whole firmware is updated/resetted?
Do you think that it is a good way to keep all RLP.Procedures as a static reference? I want to use it from different locations.
Regards
Christian
