I started experimenting with RLP process. The first thing I did was install the Yagarto tool suite as explained in the fine document “Getting started with GHI RLP”. Everything was successful.
I then unzipped the GHI RLP examples, opened a command window, changed to the appropriate directory and ran make. The make process reported an error “Command not found”. The attached screenshot shows the results.
I then executed “arm-none-eabi-gcc --version” from the command prompt and got the expected results (also shown in the screenshot) so I know the PATH is properly set.
Any suggestions as to what is causing the make error?
I changed the path where the example make file is installed to “C:\downloads\GIH_TinyCLR\RLP_User\EMX\RLP_Starter_Example\Native” which has no spaces. Same error.
I then changed the Makefile definition of CC and LD as follows:
CC =c:/yagarto/bin/arm-none-eabi-gcc
LD =c:/yagarto/bin/arm-none-eabi-gcc
The make then works as expected without errors. Since “c:\yagarto\bin” is part of my path I have no idea what’s wrong
Skip everything, open command prompt and enter “arm-none-eabi-gcc”. If you get error then your problem is not related to RLP, but in windows/GCC setup.
