Hi All,
I was wondering if there is a way to create an arbitrary waveform generator using the Fez Cobra Board. I know that I can make a square wave using the PWM functionality using .NETMF. I would also like to make a sine wave as well. I tried using the analog output function where I can write out a byte array of values at a defined frequency, but it doesn’t repeat itself fast enough to get a consistent waveform out. I was wondering if there is a way to control this analog output using the RLP interface. Thanks.
