Ok, this is a simplified version of what I’ve got so far, it sort of works, but the LED does not stay ON all the time, its flickers seemingly randomly.
So essentially I’m sending a PING every 1 second and resending PONG, when PONG is received I light a LED, in another thread i turn of the LED every 5 seconds. The problem i think is the devices are not turned on at the same time so there’s a thread.sleep difference.
I need a better way of doing this, basically if the PONG is received every 1 second there should be no chance for PingReset to fire and turn of the LED
Anyone have suggestions??
using System.IO.Ports;
using System.Net;
using System.Net.Sockets;
using System.Text;
using GHI.Hardware;
using GHI.Hardware.FEZCerb;
using Toolbox.NETMF.Hardware;
static Ic74hc595 Chain = new Ic74hc595(Pin.PA5, Pin.PA7, Pin.PA4, 2);
static SevenSegment Tens = new SevenSegment(Chain.CreateParallelOut(0), false);
static SevenSegment Ones = new SevenSegment(Chain.CreateParallelOut(8), false);
static Thread Wireless = new Thread(new ThreadStart(OnWirelessStart));
static Thread Ping = new Thread(new ThreadStart(OnPingStart));
static Thread PingReset = new Thread(new ThreadStart(OnPingResetStart));
static OutputPort Zulu_Pd = new OutputPort(Pin.PB1, false);
static OutputPort Zulu_Nrst = new OutputPort(Pin.PB0, false);
static SerialPort Zulu = new SerialPort("COM2", 4800, Parity.None, 8, StopBits.One);
Initialize();
static void Initialize()
MapDisplaySignals();
Wireless.Start();
Ping.Start();
PingReset.Start();
private static void MapDisplaySignals()
Tens.ChangeSignal(0, 63);
Ones.ChangeSignal(0, 63);
Tens.ChangeSignal(1, 6);
Ones.ChangeSignal(1, 6);
Tens.ChangeSignal(2, 91);
Ones.ChangeSignal(2, 91);
Tens.ChangeSignal(3, 79);
Ones.ChangeSignal(3, 79);
Tens.ChangeSignal(4, 102);
Ones.ChangeSignal(4, 102);
Tens.ChangeSignal(5, 109);
Ones.ChangeSignal(5, 109);
Tens.ChangeSignal(6, 125);
Ones.ChangeSignal(6, 125);
Tens.ChangeSignal(7, 7);
Ones.ChangeSignal(7, 7);
Tens.ChangeSignal(8, 127);
Ones.ChangeSignal(8, 127);
Tens.ChangeSignal(9, 111);
Ones.ChangeSignal(9, 111);
static void OnWirelessStart()
Zulu_Pd.Write(true);
Zulu_Nrst.Write(true);
Zulu.ReadTimeout = 500;
Zulu.WriteTimeout = 500;
Zulu.Handshake = Handshake.None;
Zulu.Open();
Zulu.DataReceived += new SerialDataReceivedEventHandler(Zulu_DataReceived);
static void OnPingStart()
while (true) {
Transmit("PING");
Thread.Sleep(1000);
static void OnPingResetStart()
// Turn off a DOT on a 7-segment
Chain.Pins[0].Write(false);
Thread.Sleep(5000);
static void Zulu_DataReceived(object sender, SerialDataReceivedEventArgs e)
Thread.Sleep(100);
if (Zulu.BytesToRead > 0)
Byte[] Bytes = new Byte[Zulu.BytesToRead];
Zulu.Read(Bytes, 0, Bytes.Length);
Char[] Chars = Encoding.UTF8.GetChars(Bytes, 0, Bytes.Length);
String Command = new String(Chars);
Debug.Print(Command);
if (Command == "PING")
Transmit("PONG");
if (Command == "PONG")
// Light a DOT on a 7-segment
Chain.Pins[0].Write(true);
static void Transmit(string Command)
Byte[] Data = Encoding.UTF8.GetBytes(Command);
Zulu.Write(Data, 0, Data.Length);
Thread.Sleep(100);
