Resources for Cobra Graphic Demo
Greetings,
I am working through the tutorials and found the updated code for the cobra that removed all references to Chipworx.
When I open the solution I have errors that state
Error 1 The name ‘Resources’ does not exist in the current context
Is there a resource file associated with this demo that I have not found? Or am I missing something else?
Thanks,
Ron Wensley
Support – GHI Electronics search for “loading resources”
welcome to the community
By the way, fro graphics, search the forum for “glide”
Gus,
Thank you for the reply. I will install these and see how it goes!
Ron
Gus,
I still seem to be missing something. All of the resources are okay. Now when I try and run the solution GHI_Cobre_Graphic_Demo the debugger stops with the following in the output window.
Invalid native checksum: GHIElectronics.NETMF.Hardware 0xA1518A4B!=0x9C770BE2
Resolving.
Assembly: System.Http (4.1.2821.0) needs assembly ‘System.Net.Security’ (4.1.2821.0)
Assembly: GHIGraphicalDemo (1.0.0.0) needs assembly ‘Microsoft.SPOT.TinyCore’ (4.1.2821.0)
Assembly: GHIGraphicalDemo (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.System’ (4.1.3.0)
Assembly: GHIGraphicalDemo (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.USBHost’ (4.1.3.0)
Assembly: GHIGraphicalDemo (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.IO’ (4.1.3.0)
Assembly: GHIGraphicalDemo (1.0.0.0) needs assembly ‘Microsoft.SPOT.Hardware.SerialPort’ (4.1.2821.0)
Assembly: GHIGraphicalDemo (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.Hardware’ (4.1.3.0)
Error: a3000000
The program ‘[4] Micro Framework application: Managed’ has exited with code 0 (0x0).
Waiting for debug commands…
And the Cobra LCD has the text Waiting for debug commands…
I have firmware version 4.1.6.0 and have deleted and reinstalled the SDK
Your assistance will be welcomed.
Ron
Click reply and look at note #1 :slight_smile:
Um… 4.1.6.0 is the latest version posted and it is the firmware installed on the Cobra.
Try removing the GHI references from your project and then re-add them. The listing say it is looking for GHI 4.1.3 SDK.
You always need to remove and re-add the project references when a SDK is upgraded.
Mike,
Thanks for the help that took care of it the demo is up and running. ;D
