In the FEZ Touch example I added a resource (add existing item) it was an PNG image i converted with the conversion utility.
It is visible in the resource heading, It is copied by the application to the same directory as the original img file.
The application generates the following error (Jos_bew) is my converted file.
How come the resource is not availabe. If I chage Jos_bew back to img again the error disappears and the monkey is shown again.
Who can Help,
Regards, Jos
Error 1 ‘FEZ_Touch_Example.Resources.BinaryResources’ does not contain a definition for ‘Jos_bew’ E:\PANDA II\FEZ Touch\FEZ Touch Example\FEZ Touch Example\Program.cs 63 102 FEZ Touch Example
