Hi all - I believe I’ve made some sort of common mistake, but I can’t for the life of me figure out what it is.
A program that I wrote and debugged yesterday is “suddenly” not working anymore (note the quotes, I MUST’ve done something, of course!)
The output from debug is the following:
Found debugger!
Create TS.
Loading start at 20251ea0, end 202871d4
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.3.1.0) Assembly: System.Xml (4.3.1.0)
Assembly: Microsoft.SPOT.Time (4.3.1.0) Assembly: Microsoft.SPOT.Net (4.3.1.0)
Assembly: System (4.3.1.0) Assembly: Microsoft.SPOT.Net.Security (4.3.1.0)
Assembly: System.Net.Security (4.3.1.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.EthernetENC28 (4.3.7.9) Attaching deployed file.
Assembly: GHI.Hardware (4.3.7.9) Attaching deployed file.
Assembly: GTM.GHIElectronics.CharacterDisplay (4.3.7.9) Attaching deployed file.
Assembly: CareForPlant (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Moisture (4.3.7.9) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.3.7.9) Attaching deployed file.
Assembly: Gadgeteer.SPI (2.43.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.LightSense (4.3.7.9) Attaching deployed file.
Assembly: GHI.Networking (4.3.7.9) Resolving.
Resolve: unknown type: System.Diagnostics.DebuggerBrowsableState
Error: ff000000
Waiting for debug commands...
The program '[9] Micro Framework application: Managed' has exited with code 0 (0x0).
And the output from Service Deployment is:
Looking for a device on transport 'USB'
Starting device deployment...
Iteration 0
Opening port \\?\usb#vid_1b9f&pid_0102#0000000001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Attaching debugger engine...
... debugger engine attached!
Querying device assemblies...
Found Assembly mscorlib 4.3.1.0
Found Assembly Microsoft.SPOT.Native 4.3.1.0
Found Assembly Microsoft.SPOT.Security.PKCS11 4.3.1.0
Found Assembly System.Security 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware 4.3.1.0
Found Assembly Microsoft.SPOT.Graphics 4.3.1.0
Found Assembly Microsoft.SPOT.TinyCore 4.3.1.0
Found Assembly Microsoft.SPOT.IO 4.3.1.0
Found Assembly System.IO 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.Usb 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.SerialPort 4.3.1.0
Found Assembly Microsoft.SPOT.Touch 4.3.1.0
Found Assembly Microsoft.SPOT.Ink 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.PWM 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.OneWire 4.3.1.0
Found Assembly System.Xml 4.3.1.0
Found Assembly Microsoft.SPOT.Time 4.3.1.0
Found Assembly Microsoft.SPOT.Net 4.3.1.0
Found Assembly System 4.3.1.0
Found Assembly Microsoft.SPOT.Net.Security 4.3.1.0
Found Assembly System.Net.Security 4.3.1.0
Found Assembly Gadgeteer 2.43.1.0
Found Assembly GHI.Hardware 4.3.7.9
Found Assembly GTM.GHIElectronics.CharacterDisplay 4.3.7.9
Found Assembly GHI.Networking 4.3.7.9
Found Assembly CareForPlant 1.0.0.0
Found Assembly Gadgeteer.SPI 2.43.1.0
Found Assembly GHIElectronics.Gadgeteer.FEZHydra 4.3.7.9
Found Assembly GTM.GHIElectronics.EthernetENC28 4.3.7.9
Found Assembly GTM.GHIElectronics.Moisture 4.3.7.9
Adding pe file C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies\.NET Micro Framework 4.3\le\gadgeteer.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\.NET Gadgeteer SDK\Modules\EthernetENC28\NETMF 4.3\le\gtm.ghielectronics.ethernetenc28.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.hardware.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\.NET Gadgeteer SDK\Modules\CharacterDisplay\NETMF 4.3\le\gtm.ghielectronics.characterdisplay.pe to deployment bundle
Adding pe file D:\Dev\Private\IoT\Gadgeteer\Hydra\WaterMyPlant\WaterMyPlant\CareForPlant\bin\Debug\le\CareForPlant.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\.NET Gadgeteer SDK\Modules\Moisture\NETMF 4.3\le\gtm.ghielectronics.moisture.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\.NET Gadgeteer SDK\Mainboards\FEZHydra\NETMF 4.3\le\ghielectronics.gadgeteer.fezhydra.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies\.NET Micro Framework 4.3\le\gadgeteer.spi.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\.NET Gadgeteer SDK\Modules\LightSense\NETMF 4.3\le\gtm.ghielectronics.lightsense.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.networking.pe to deployment bundle
Attempting deployment...
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 110376 bytes
Assemblies successfully deployed to device.
Restarting interpreter...
Attaching to device...
Waiting for device to initialize...
I am running the 4.3 Version of .Net Micro Framework, and the corresponding Libraries.
Could it be that I am simply missing some framework Library? According to the Object browser, the missing type “System.Diagnostics.DebuggerBrowsableState” can be navigated to, but exerience has taught me that namespaces are not necessarily tied to the dll. Any input largely appreciated!
