Under what circumstances should a custom module reserve pins?
For example, I assume that a module using UART on Socket 11 of the Spider should reserve pins 4 and 5 for TX/RX, right?
When I try that, I get this:
[quote]Using mainboard GHIElectronics-FEZSpider version 1.0
#### Exception Gadgeteer.Socket+PinConflictException - 0x00000000 (1) ####
#### Message:
Unable to configure the MidiModule module using socket 11 (pin 4). There is a conflict with the MidiModule module using socket 11 (pin 4). Please try using a different combination of sockets.
#### Gadgeteer.Socket::ReservePin [IP: 003a] ####
#### Gadgeteer.Interfaces.Serial::.ctor [IP: 00ec] ####
#### Gadgeteer.Modules.PeteBrown.MidiModule::.ctor [IP: 007a] ####
#### GadgeteerMidiTest.Program::.ctor [IP: 0006] ####
#### GadgeteerMidiTest.Program::Main [IP: 000b] ####
A first chance exception of type ‘Gadgeteer.Socket.PinConflictException’ occurred in Gadgeteer.dll
An unhandled exception of type ‘Gadgeteer.Socket.PinConflictException’ occurred in Gadgeteer.dll[/quote]
However, if I run without that check, it works. I’m not sure if another module I’m using could potentially conflict, or if I’m doing something wrong with the check.
public MidiModule(int socketNumber)
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
// need a UART/USART socket.
if (!socket.SupportsType('U'))
throw new GT.Socket.InvalidSocketException("Socket '" + socketNumber + "' does not support the MIDI module. Please plug the MIDI module into a socket labeled 'U'.");
// can't share the send/receive pins
try
socket.ReservePin(Socket.Pin.Four, this);
socket.ReservePin(Socket.Pin.Five, this);
catch (Exception e)
throw new GT.Socket.InvalidSocketException("Could not reserve required pins for MIDI serial communications on socket '" + socketNumber + "'.");
// initialize serial comms
_serial = new GTI.Serial(
socket,
31250,
GTI.Serial.SerialParity.None,
GTI.Serial.SerialStopBits.One,
8,
GTI.Serial.HardwareFlowControl.NotRequired,
this);
// open ze port
_serial.Open();
Awesome MSPaint artwork attached.
Pete
