Can you help me getting the Insert / Eject event to work? Nothing appears in the output window when inserting or removing my SD-Card.
Regards
using System.IO.Ports;
using Microsoft.SPOT.IO;
namespace MicroRemote
RemovableMedia.Insert += new InsertEventHandler(RemovableMedia_Insert);
RemovableMedia.Eject += new EjectEventHandler(RemovableMedia_Eject);
Utility.Piezo(1000, 500);
using (InputPort port = new InputPort((Cpu.Pin)FEZ_Pin.Digital.ButtonSelect, true, Port.ResistorMode.PullUp))
while (port.Read())
Thread.Sleep(100);
static void RemovableMedia_Eject(object sender, MediaEventArgs e)
Debug.Print("eject");
static void RemovableMedia_Insert(object sender, MediaEventArgs e)
Debug.Print("insert");
I don’t think they have this for SD media… The GHI demo uses the persistent storage class and uses “detect media” to ascertain if a card is inserted or not… You could set up a class to poll the SD card and return the media status…
Cheers Ian
P.S. some cards are not detected… read the class help in the object browser.
Ok, since I didn’t like the idea of spawning a thread for card detection I’ve worked out the following class by using InterruptPort. Maybe the InterruptPort spawns a thread anyway (and I think it does since you can enable the glitch-filter).
/// <summary>
/// Detects insertion / removal of SD-CARD for FEZ Cobra.
/// Programmed by Huysentruit Wouter
/// </summary>
public class SdCard : IDisposable
#region Declarations
private InterruptPort interrupt = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.IO33, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
private PersistentStorage storage = null;
private VolumeInfo volume = null;
#endregion
#region Construction / destruction
public SdCard()
interrupt.OnInterrupt += new NativeEventHandler(sdDetectInterrupt_OnInterrupt);
try
if (PersistentStorage.DetectSDCard())
storage = new PersistentStorage("SD");
storage.MountFileSystem();
volume = new VolumeInfo("SD");
catch (Exception)
storage = null;
volume = null;
public void Dispose()
interrupt.Dispose();
ReleaseStorage();
#endregion
#region Private methods
private void ReleaseStorage()
lock (this)
if (storage != null)
storage.UnmountFileSystem();
storage.Dispose();
storage = null;
private void sdDetectInterrupt_OnInterrupt(uint port, uint state, DateTime time)
// Read input again since the state argument seems unreliable
if (interrupt.Read())
ReleaseStorage();
OnEject(time);
lock (this) volume = null;
lock (this)
OnInsert(time);
#endregion
#region Exposed events
/// <summary>
/// Fired when inserting a valid SD card.
/// </summary>
public event InsertEventHandler Insert;
private void OnInsert(DateTime time)
if (Insert != null)
Insert(this, new MediaEventArgs(volume, time));
/// <summary>
/// Fired when removing the SD card.
/// </summary>
public event EjectEventHandler Eject;
private void OnEject(DateTime time)
if (Eject != null)
Eject(this, new MediaEventArgs(volume, time));
#endregion
#region Properties
/// <summary>
/// Gets the volume information of the SD card or null when no card was inserted.
/// </summary>
public VolumeInfo Volume
get { lock (this) return volume; }
/// <summary>
/// Gets a value that indicates wheter or not the SD card is available.
/// </summary>
public bool Available
get { lock (this) return storage != null; }
#endregion
Wouter Huysentruit … I cannot find any other way to contact you.
Sorry …
But on your Fezzer Sunrise/Sunset calculation there are problems:
#1. The source code on download is lock-out eg classes are greyed out. #2. The sunrise and sunset times are reversed. It is not the print statement in your example but comes from the source code greyed out. #3. The sunrise if off by 8 minutes and the sunset time is off by 11 minutes by using several on-line web-based sunrise/sunset calculators.
:o :o :o
