Is there a way in code to know if it is running as Debug or Release?
DeviceInformation.DebugInterface() does not help. It returns the same result regardless of Debug/Release.
use conditional compilation?
Check Debugger.IsAttached which will be true if you are connected via debug cable.
Do you mean the debug/release build option, as I assumed, or whether the debug cable was attached as Dave assumed?
This should explain it. If Debug do x otherwise do y.
Thank you, everyone, for the suggestions. Very helpful.
