@ John -
Thanks for the reply… I asked because I ‘thought’ that maybe you update the core.
Anyway, I’m wrong as usual!
@ John -
In 4.3.5 “SDCard.IsCardInserted” was removed.
What can I use instead!?
@ Reinhard Ostermeier - You can create an interrupt port on the SD detect pin (pin 3 on the F socket) and mount or unmount when you receive an interrupt.
@ John - But that will not work on Cobra II. SD detect pin does not support interrupts.
@ John - I have a custom board, where SD_CD is connetcted to P1.8
And I don’t need Interrupts, because I only Need to detect if SD Card is present on Startup.
Thank you for the info.
@ Reinhard Ostermeier - Happy to help.
@ willgeorge
I fixed a problem with the web server null responder object in this post, item #6
https://www.ghielectronics.com/community/forum/topic?id=15039&page=1#msg151649
I changed the source code for the NETMF webserver and made my own DLL.
Your support page instructs me to use .NET Gadgeteer Core 2.43.900
https://gadgeteer.codeplex.com/releases/view/119122
But there is a newer version available:
.NET Gadgeteer Core 2.43.1000
https://gadgeteer.codeplex.com/releases/view/134757
Should I be using Gadgeteer Core 2.43.1000?
@ dspacek - We currently support 900, but you should be fine using 1000. See https://www.ghielectronics.com/docs/319/latest-microsoft-sdk-releases for more information on it.
Thanks for all work !!!
Thanks! GHI developers and staff. Great Job!
How can I track the progress with the work Microsoft is doing to fix the LwIP TCP/IP stack issues in discussion 569521? I looked here:
https://netmf.codeplex.com/SourceControl/list/changesets
and no code changes have been made since Oct. 31, so it seems that work has stopped. Is there a projected release date for the next .NET Micro Framework that will fix these problems?
@ dspacek - typically Microsoft does all changes locally and only push up when all is done. Not seeing changes on codeplex doesn’t mean anything really.
