I feel like I’m missing something really obvious here, and if that is the case, I will apologize profusely … until that happens, I’m hoping somebody on this forum can help me out …
I have code uses the internal TIMx timers of the Cerbuino Bee.
The following is an example of code that works exactly as I would expect …
MyTIMRegister.SetBits(1 << 0 | 1 << 4); //This sets Bits 0 and 4 in the register
However, when I want to set the left-most bit in the register (Bit 31), I do this:
MyTIMRegister.SetBits(1 << 31);
And I get a compiler error "Error 2 Argument 1: cannot convert from ‘int’ to ‘uint’ RegisterUtilities.cs 137 33 MotorController
Am I missing something obvious here?
Is there an alternate bitmask that will set ONLY the left-most bit to 1?
In addition to @ Architect’s answer, another option is to use the numeric suffix you could use
MyTIMRegister.SetBits(1u << 31);
or
MyTIMRegister.SetBits(1U << 31);
While suffixes can be either upper or lower case, the upper case suffix is usually preffered because l is potentially confused with 1 while L is easily distinguished.
@ Architect - Tx, I marked your answer because it fixes the problem. In hindsight, I can see why also (Visual Studio treats numbers as signed by default).
However, I do have a follow-up question …
Why do you suggest the format “MyTIMRegister.SetBits(0x80000000)” is better?
It shows you explicitly what bit you are setting. There is no need to reconvert the 0x80… into figuring out the flag you mean.
If you use a constant for the shift-offset, then you can easily reflect the function of that mask. If your register has to change, you just change your constant.
One reason I can suggest Architect might suggest the 0x80… format is better is because its explicit - it’s an unsigned int and there’s no need to cast it.
In all cases the IL is exactly the same, a constant value is loaded onto the stack. No self respecting compiler would not perform constant folding, even in debug builds. Personally I also favor the (1 << x) version for readability, but that is a personal opinion.
