Did you check out Dangerous Prototypes’ review and video of it before you lashed out? Seems like you’re stepping up in the maker world - next a PnP machine? DP have one of those too
I have the very same unit. The only advise I would offer is to watch it for heat as internally the tape they use to secure the insulation is not that temperature resistant. My unit was basically masking take.
No biggy to change if you want a little more safety in mind. I bought some high temperature tape from Farnell and all is fine now and the smell is also gone
I have the same unit, and I’ve had good results. If boards are too close to the front of the unit, they don’t hit the temperatures needed to properly melt the solder paste. That’s the only problem I’ve had with it.
It’s super easy to use and comes with pre-defined profiles for every paste I’ve ever used.
The manual is definitely hilarious. Here’s an excerpt:
