I am looking for a good multimeter capable of measuring wide range of capacitors, ESR, etc.
Basically looking for the best out there. Right now I have generic RadioShack unit and it was enough so far. Now I need something more “advanced”.
This is related to my attempts to fix the TV, I have posted earlier. I would like to identify bad caps if any on that board (preferably without desoldering them first) .
Fluke is hands down one of the best meters out there. Can take allot of abuse as well.
But honestly, almost any meter today are very accurate. If your looking to get down to 0.001 then go with fluke. Otherwise most El-cheapos work just fine.
In my entire working career i have only NEEDED to use the fluke a few times. Most of the time i just use my china meter that i got for $25 which has been more than accurate enough for all things.
IMHO people get to wrapped up in the accuracy of a meter. If you not having them calibrated once per year, there really is no point in a high priced meter.
the Uni-t range are quite good and you can get pretty cheap too.
This one looks quite nice Review - UNI-T UT81B Scope / Meter | diyAudio as its a scope meter with opto isolated USB to allow you to hook it up to the PC.
Ive got a Uni-t 60a but its an older model and has an opto isolated RS232 and some basic software (i managed to persuade it to run with win 7) but the meter is good and easy to use.
What additional features are you looking for, specifically?
For basic DMM stuff, I’ve been quite happy with my Extech EX210, which was recommended by @ swestcott in his “Complete Idiot’s Guide to Electronics 101” book.
I specifically wanted the wireless connection, after working on tiny devices using sewing needles for probes I don’t to jog my hands when lifting my head to read a display, and I plan to add test-to-speech software to get around this.
The meter comes with its own software, pretty basic, gives you a big display, graphs, logged data at various periods and the ability to save. However the Wireless USB is pretty simple, a Silicon Labs UART bridge at the PC end, it pops up as a COM port at 2400bps, spitting out 19-byte packets containing info such as current mode and reading.
I just need to decode that, wrap it in a few smarts (hysteresis on reading out values so it doesn’t drive me mad, limits, etc) and add voice, and I should be in business!
@ C-Born, I can see where the wireless USB feature would be really nice. I haven’t seen that before. Now you have me wanting to upgrade my $25 DMM. Thanks…alot… If only it had the capacitance checker that Architect is seeking.
