the fez ultimate kit plus a relay e-block, an assorment package from ebay of transistors, an assorment package of 1/4w resistors, another for capacitors, a 10v power supply, a 400 contacts breadboard, jumper cables
I already have the solder and multimeter.
This is my starting package…in 3 weeks i’ll order the battery and charger/booster, and others devices i will need for my little project…meanwhile when i get all this i will start inventing that black hole
By this I hope you mean you have a good variable temperature soldering station. If you have one of the $10 Radio Shack irons prepare for frustration. The day I bought a good soldering station was the same day I really learned to solder. Before that it was just mess after mess… I bought a Kada 852D+ off eBay for about $75. Best $75 I’ve spent on this hobby.
sadly I don’t have that spaceship ;D. Just a solder…i will look into buying something more safe and confortable…remember i’m just starting on this hobby, I know how to solder when coaxial cable where used on networks, i’m in IT.
Sparkfun still has in stock their “Soldering Station Variable Temperature 50W - Analog (AT936B)” which is a clone of the Hakko 936. It’s actually an “Atten 936b”, but they speak highly of it. It’s only $29.95 and cheap shipping can be had:
let’s say that i don’t want to use the remote box with a battery.
Can i inteface the panda II with the touch using a cable? How long that cable can be?
If i can do it that way, i can just put the touch on some enclosure connected to the main box with a cable and for remote control use IR to set some things.
It can not be very long. The touch is connecting directly to the header on the Panda II, that means it is working at low voltage signaling at best which will work best with short lengths. To extend the length significantly you’ll need to convert the signalling to something designed for longer lengths. If timing is important though, it may not handle the overhead of such transition. Just guessing.
well…i will use the remote box anyway, so i can learn more
another question :
i’m waiting for my order of the ultimate kit and all the components to arrive, I ordered a 10v 1A power suply to power the main box…that is ok? or do i need (can have) less or more?
I’m using a 12V wall wart for dev w/o any problems. I’d want something in the recommended range though for something that’ll be running all the time. I’m sure Gus will ring in here in a few minutes with a more definite answer…
