Hi Guys,
I have some simple test code here for a UDP Listener:
public bool StartListener(int nPort)
m_ListenerSocket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
try
// bind the listening socket to the port
IPEndPoint ipLocalPort = new IPEndPoint(IPAddress.Any, nPort);
m_ListenerSocket.Bind(ipLocalPort);
catch (Exception ex)
Debug.Print("Cannot connect to port");
Debug.Print(ex.ToString());
return false;
// start listening
byte[] buffer = new byte[1024];
if (m_ListenerSocket.Poll(-1, SelectMode.SelectRead))
Debug.Print("Data Ready");
m_ListenerSocket.Receive(buffer);
Debug.Print(new string(System.Text.Encoding.UTF8.GetChars(buffer)));
return true;
This runs fine in the emulator no problems at all.
When run on the Cobra I get an exception on the .Receive() line:
Data Ready
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (1) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::recv [IP: 0000] ####
#### System.Net.Sockets.Socket::Receive [IP: 0018] ####
#### System.Net.Sockets.Socket::Receive [IP: 0010] ####
#### CADTestNetwork.CADUDPListener::StartListener [IP: 0065] ####
#### CADTestNetwork.Program::Main [IP: 000e] ####
#### SocketException ErrorCode = 10057
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
An unhandled exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
Does the Cobra not support the normal microsoft socket stuff and I need to use some FEZ alternative?
Thanks for any help
Andy
Socket Error 10057 means: “Not Connected”.
Try setting your SocketType to Stream
Thanks for the reply.
You cannot useSocketType.Stream with ProtocolType.Udp.
Cheers
Andy
Hi Guys,
Looks like you have to use RetrieveFrom() when running on the Cobra, no idea why this differs from the emulator! Anyone any ideas?
So the following works:
EndPoint ipLocalPort;
try
return false;
// start listening
m_ListenerSocket.ReceiveFrom(buffer, ref ipLocalPort);
return true;
Cheers
Andy
The emulator is “emulating” the sockets interface with a layer between, it may be doing something it shouldn’t. UDP is a connectionless protocol, you must use ReceiveFrom instead of Receive.
If I have an exception in a system function like Receive, I like to look at the docs to make sure I’m using it correctly
The Receive method will read only data that arrives from the remote host established by the Connect or Accept method. If you are using a connectionless protocol, you can also use the ReceiveFrom method, which enables you to receive data arriving from any host.
I must admit I jumped to the conclusion that receive should work as it worked in the emulator and also the endpoint was already bound to the socket!
I promise to read the documentation more closely next time
I’m not giving you hell for it, just a friendly suggestion The .NETMF docs are pretty sparse, so whatever info contained is usually pretty essential. Not lots of paragraphs/descriptions like the Win32 API for every single call
No Problem, you are quite correct.
UDP stuff I have done in .NET has always been done using UDPClient which doesn’t seem to be in NETMF (even though the documentation states it is!).
See I read the docs sometimes
