Hello,
could it be possible to add (to the already long list, I know ) a small âReasonâ field when we edit a message ?
Itâs always good to know why a post has been edited, I think.
Hello,
Thanks for the input. Does anyone second this? Required or optional?
99% of the time I edit a posting it is to correct a spelling or missing word.
I vote nay.
Vote : no
As Mike says, most of the time we edit posts to correct spelling.
You can add the reason manually if you want to.
Letâs keep posting FEZ
Edit: Instead, a nice feature would be to not add the âLast EditâŚâ message if the post is modified by its author 5 minutes after the creation
I like your suggestion randoom.
I agree with Randoom. good idea Bec, but mostly itâs a grammar reason.
I didnât expect it to be a âgoodâ idea, only an idea
I also agree with randoomâs suggestion.
But⌠please read his last message more carefully : why did he edit it ? :whistle:
Ok, there are 2 main reasons the posts are modified: spelling & things we forget.
You could add a âreasonâ field but donât make it ârequiredâ
Of course it wouldnât be a required field
Yes defiantly optional, not required.
I am on NO side.
Because I just donât want to explain why I couldnât upload the image when I didnât loade the proper image file format!
Iâm on the NO side as well.
(Sorry Bec a Fuel)
It doesnât bother me if you donât agree on this idea.
Iâm used to bad ideas :-[
No side. Only reason I edit is to correct small stuff.
I second this, if it was optional
No from here as well.
But what about making some members âmoderatorsâ. I often see posts with code not using the code button, and that makes it hard to read the code. btw, i volunteer
I could volunteer to be mod, too. If thatâs some way to earn a second Cobra :o
I personally add my own info in there if I think my edit is worthy of noting - but really the number of times that its necessary is not that big. Optional, sure I can understand it might be valuable to some, but will people use it.
Adding mods could be handy. But adding mods for small things like âsomeone forgot to use the code buttonâ is overdone.
Itâs better that the user gets notified of the code button instead. Otherwise they keep doing it wrong.
I volunteer of course, but I donât think itâs necessary to have them
^^^ If people donât use the code tags I will usually not read their code.
