HI Gus,
I’ve tried all the combinations.
Power to VBat yes/no and 32khz crystal + 2x6pf caps to D4/D5 + gnd. yes/no
No. Luck.
I suppose I was wondering if it ever worked? Or was this a defect that was never resolved?
I’ll retest the hardware…
Guy
Hi Dat,
I am using a CerbuinoNet board and soldered a 32khz crystal to 2 pin, connected two 6pf to those pins and added a ground lead to the two other ends of the caps.
I then plugged the 2 pins in D3 and D4 and connected the ground wire to ground.
I also have a 3V cr2032 connectedto vbat.
I noticed that the clock never ‘ticks’. Ie. it’s always stuck at midnight.
And when I try and set it, it hangs forever
Guy
not thread jacking, but perhaps the xtal is not matching the load caps? See Cerbuino RTC help - #18 by untitled (the thread went cold after that person went off to buy new xtal and caps)
