The size of the drive is 4,2 GB.
Writing to the drive is no problem.
Even copying files, renaming files, … no problem.
I just tested it: reading 150 chars: no problem.
The 500 chars was just a test to debug my program.
That’s why I was reading only 5 bytes at a time.
The file could be much shorter, or longer: it’s generated by the customer.
Some other interresting point:
- the “Read Status Register” J command, always returns $00. Even when the U1 drive is mounted (and logging) or not.
- the set “Current Time and date” S command does not work:
When sending " S 34212002" (your example in the manual), it will return !00. But when you look at the Date created on a PC, it’s always 31 Dec 1978 23:00
I’m controlling the alfat module from a atXmega128
