We’ve been using the Cerb Bee for a while now without problems. Today someone who was assembling a new unit called me over. Apparently this one particular board wouldn’t keep time. So I took a look at it. The first thing I noticed was that it had a 16GB SD Card instead of the 2GB SD Cards we use. Odd but unimportant, this 16GB SD Card had a green back where normally they’re black. At any rate, I replaced the crystal and coin cell twice. I’ve triple checked all the wiring. Normally we use an app I wrote to deploy our firmware and code, but in this case I manually erased and deployed firmware using MFDeploy directly. Still not keeping time. It sets the time just fine, but then I reboot and it’s lost. Any ideas? Could this be a defective unit? What else should I check?
I’m running a simple test app on it now. First I run this program…
if (GHI.OSHW.Hardware.RTC.GetTime().Year == 1980)
GHI.OSHW.Hardware.RTC.Initialize();
GHI.OSHW.Hardware.RTC.SetTime(new DateTime(2013, 1, 1, 1, 1, 1, 1));
Utility.SetLocalTime(GHI.OSHW.Hardware.RTC.GetTime());
And view DateTime.Now, then I remove power, re-attach it and run this code…
And my date is always back to 1980. This is running the same firmware my working boards have. I’ve replaced the crystal and battery three times now.
…And I had 3.3v on pin 1 on the processor for vbat.
I’m returning this board. We’ve bought a lot of these, this is the only board with this problem. I have no idea what could cause it, but I’m convinced it’s bad.
