I want to read my PV-installation with a RS485 module on my raptor. Then I want to upoad the data to an Azure Eventhub via the AMQP protocol.
Both parts of the code works if I test them seprate but if I combine those 2 modules and code, the RS485 module does not always receives the correct data. Also the ethernet starts to fail. (Exception was thrown: System.Net.Sockets.SocketException-Microsoft.SPOT.Net.SocketNative::getaddrinfo-System.Net.Dns::GetHostEntry)
I’ve upgraded the raptor to the latest firmware (2015 relaese) but the problem remains.
Does anyone has the same problem?
regards
Joris
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using Amqp;
using Amqp.Framing;
using Json.NETMF;
using System.Text;
using Amqp.Types;
using System.IO;
using System.IO.Ports;
using GHI.Networking;
using Gadgeteer;
namespace TestRaptorSB
public partial class Program
private const string eventhubAddress = "amqps://...";
private const string EntityPath = "testeh";
GT.Timer timer;
Program.Mainboard.LDR1.OnInterrupt += LDR1_OnInterrupt;
address = new Address(eventhubAddress);
timer = new GT.Timer(10000); // every second (2000ms)
timer.Tick += timer_Tick;
this.ethernetENC28.NetworkUp += ethernetENC28_NetworkUp;
this.ethernetENC28.UseThisNetworkInterface();
this.ethernetENC28.UseStaticIP("192.168.0.3", "255.255.255.0", "192.168.0.1", new string[] { "195.130.131.4", "195.130.130.132" });
rs485Left.Configure();
rs485Left.Port.LineReceived += Port_LineReceived;
rs485Left.Port.Open();
Amqp.Trace.TraceListener = this.Tracer;
Amqp.Trace.TraceLevel = TraceLevel.Verbose;
private void Tracer(string format, params object[] args)
this.Log("Amqp: " + Amqp.Fx.Format(format, args));
private void Port_LineReceived(GT.SocketInterfaces.Serial sender, string line)
this.Log("RS485: " + line);
void ethernetENC28_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print(sender.NetworkSettings.IPAddress);
this.startNetwork();
void startNetwork()
Microsoft.SPOT.Time.TimeService.SetTimeZoneOffset(2 * 60); // default to GMT Offset * 60 minutes
Microsoft.SPOT.Time.TimeServiceSettings tsettings = new Microsoft.SPOT.Time.TimeServiceSettings();
string primary = "ntp.telenet.be";
string secondary = "time-a.nist.gov";
System.Net.IPHostEntry primaryIP = System.Net.Dns.GetHostEntry(primary);
System.Net.IPHostEntry secondaryIP = System.Net.Dns.GetHostEntry(secondary);
tsettings.ForceSyncAtWakeUp = false;
tsettings.RefreshTime = 5 * 60;
tsettings.PrimaryServer = primaryIP.AddressList[0].GetAddressBytes();
tsettings.AlternateServer = secondaryIP.AddressList[0].GetAddressBytes();
tsettings.AutoDayLightSavings = true;
Microsoft.SPOT.Time.TimeService.Settings = tsettings;
Microsoft.SPOT.Time.TimeService.SystemTimeChanged += TimeService_SystemTimeChanged;
Microsoft.SPOT.Time.TimeService.UpdateNow(5);
Microsoft.SPOT.Time.TimeService.Start();
timer.Start();
void TimeService_SystemTimeChanged(object sender, Microsoft.SPOT.Time.SystemTimeChangedEventArgs e)
this.Log(string.Concat("SystemTimeChanged. New Time: ", DateTime.Now));
Address address = null;
Connection connection = null;
Session session = null;
SenderLink sender = null;
private void InitializeAmqp()
this.Log("InitializeAmqp-1");
connection = new Connection(address);
this.Log("InitializeAmqp-2");
session = new Session(connection);
this.Log("InitializeAmqp-3");
sender = new SenderLink(session, "sender-" + EntityPath, EntityPath);
this.Log("InitializeAmqp-4");
connection.Closed = this.onConnectionClosed;
this.Log("InitializeAmqp-5");
private void onConnectionClosed(AmqpObject sender, Error error)
connection = null;
session = null;
sender = null;
this.Log("onConnectionClosed: " + sender.GetType().FullName);
this.Log(" Description: " + error.Description);
this.Log(" Condition: " + error.Condition.ToString());
this.Log(" Descriptor.Code: " + error.Descriptor.Code);
this.Log(" Descriptor.Name : " + error.Descriptor.Name);
foreach (var x in error.Info.Keys)
this.Log(" Info: " + x + " - " + error.Info[x]);
private void Log(string message)
try
Debug.Print(message);
if (this.sdCard.IsCardMounted)
lock (this.sdCard)
using (var filestream = new FileStream(Path.Combine(this.sdCard.StorageDevice.RootDirectory, "Test.log"), FileMode.Append))
using (var streamWriter = new StreamWriter(filestream))
streamWriter.WriteLine(string.Concat(DateTime.Now, "\t", message));
streamWriter.Flush();
streamWriter.Close();
catch (Exception ex)
Debug.Print(ex.Message);
if (!this.ethernetENC28.IsNetworkUp)
this.Log("!IsNetworkUp");
return;
if (!this.ethernetENC28.IsNetworkConnected)
this.Log("!IsNetworkConnected");
return;
timer.Stop();
try
if (connection == null) this.InitializeAmqp();
Hashtable hashtable = new Hashtable();
hashtable.Add("Datum", DateTime.Now);
// Serialize hashtable into JSON
JsonSerializer serializer = new JsonSerializer(DateTimeFormat.Default);
string payload = serializer.Serialize(hashtable);
// Create the AMQP message
var message = new Message();
var data = new Data();
data.Binary = Encoding.UTF8.GetBytes(payload);
message.BodySection = data;
message.Properties = new Properties()
Subject = "wthr",
CreationTime = DateTime.UtcNow,
ContentType = "text/json",
message.MessageAnnotations = new MessageAnnotations();
message.MessageAnnotations[new Symbol("x-opt-partition-key")] = "FezRaptor";
message.ApplicationProperties = new ApplicationProperties();
message.ApplicationProperties["time"] = message.Properties.CreationTime;
message.ApplicationProperties["from"] = "FezRaptor";
message.ApplicationProperties["dspl"] = "FezRaptor";
this.Log(" Sending");
sender.Send(message);
this.Log(" Send: ");
this.Log(ex.Message + "-" + ex.StackTrace);
finally
timer.Start();
void LDR1_OnInterrupt(uint data1, uint data2, DateTime time)
try
Debug.Print("LDR1_OnInterrupt");
if (this.sdCard.IsCardMounted) this.sdCard.StorageDevice.Volume.FlushAll();
catch (Exception) { }
