Cobra board did not have this problem. I am using .NETMF 4.2. My code is making an HTTP request every 30 seconds to a web server. It works ok for about 30 minutes, then the exception is thrown.
Here is an example activity log:
StatusMonitorLoop() - InputCoilStatus changed
13:38:57.290 Request: http://192.168.8.134/api/device/03f6dd58-b27f-7c5a-921d-711d014f836a/notification
13:38:57.313 Method = POST ContentType = application/json Auth-DeviceID = 03f6dd58-b27f-7c5a-921d-711d014f836a Timeout = 120000 Body = {“notification”: “EquipmentStatus”, “parameters”: { “Left Traffic Eye X2”: “Unblocked”, “Right Traffic Eye X3”: “Unblocked”, “PLC Status”: “OnLine”, “equipment”: “CONTROLLER”, “PLC Error Code”: “RECEIVE_SUCCESS”, “Front Traffic Eye X0”: “Blocked”, “Back Traffic Eye X1”: “Unblocked” }}
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (230) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::socket [IP: 0000] ####
#### System.Net.Sockets.Socket::.ctor [IP: 001f] ####
#### System.Net.HttpWebRequest::EstablishConnection [IP: 0132] ####
#### System.Net.HttpWebRequest::SubmitRequest [IP: 0019] ####
#### System.Net.HttpWebRequest::GetRequestStream [IP: 0008] ####
#### SocketException ErrorCode = 10055
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in System.Http.dll
13:38:57.668 GetRequestStreamAsync(): System.Net.Sockets.SocketException
The thread ‘’ (0xe6) has exited with code 0 (0x0).
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (11) ####
#### Message:
#### DeviceHive.HttpClient::GetRequestStreamAsync [IP: 002d] ####
#### DeviceHive.HttpClient::MakeRequest [IP: 00e2] ####
#### DeviceHive.HttpClient::PostNotification [IP: 0039] ####
#### DeviceHive.DeviceEngine::SendNotification [IP: 003d] ####
#### DeviceHive.EquipmentEngine::SendNotificationList [IP: 002b] ####
#### SmartTruckRaptor.BusinessLogic::SendNotification [IP: 0005] ####
#### SmartTruckRaptor.BusinessLogic::StatusMonitorLoop [IP: 012b] ####
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in HttpClient.dll
08/07/2014 13:38:57 Exception in StatusMonitorLoop(): Exception was thrown: System.Net.Sockets.SocketException
08/07/2014 13:38:57 DeviceHive.HttpClient::GetRequestStreamAsync
Here is my code for the HTTP request. The function GetRequestStreamAsync() has thread that calls GetRequestStream(), which throws the exception.
using System.Net;
using System.IO;
using Json.Serialization;
using System.Text;
using System.Collections;
using GT = Gadgeteer;
//using GTME = Gadgeteer.Modules.GHIElectronics;
namespace DeviceHive
/// <summary>
/// HTTP client for restful HTTP service
/// </summary>
/// <remarks>
/// Complies to HTTP protocol v.6.
/// Implements device-specific commands for .NET Micro Framework device.
/// </remarks>
public class HttpClient : IFrameworkClient
public string CloudUrl { get; set; }
private const string PutMethod = "PUT";
private const string GetMethod = "GET";
private const string PostMethod = "POST";
private const string DeleteMethod = "DELETE";
private const string ContentType = "application/json";
//private const string PutDeviceCommand = "/device";
private const string InfoCommand = "/info/";
private const string DeviceCommand = "/device/";
private const string NotificationCommand = "/notification";
private const string PollCommandName = "/command/poll?timestamp=";
//private const string GetCommandName = "/command?start=";
private const string CommandStatus = "/command/";
// v6
private const string IdHeader = "Auth-DeviceID";
private const string KeyHeader = "Auth-DeviceKey";
private Queue CommandQueue;
private string lastTimeStamp;
private int AsyncTimeout;
//private int counter;
/// <summary>The Button module using socket 11 of the mainboard.</summary>
/// <summary>
/// Constructs an HTTP client object
/// </summary>
/// <param name="Url">URL of the DeviceHive server</param>
/// <param name="RequestTimeout">Maximum request timeout</param>
/// <param name="TimeStamp">Timastamp of the last command</param>
/// <remarks>
/// If the caller has no intention to set a specific time stamp, DeteTime.MinValue can be used.
/// </remarks>
public HttpClient( string Url, int RequestTimeout, string TimeStamp = null)
CloudUrl = Url;
CommandQueue = new Queue();
AsyncTimeout = RequestTimeout;
LastTimeStamp = TimeStamp;
private string LastTimeStamp
get
if (lastTimeStamp == null)
lastTimeStamp = GetApiInfo().serverTimestamp;
return lastTimeStamp;
set
lastTimeStamp = value;
//public Device GetDevice(Guid id)
// HttpWebRequest req = HttpWebRequest.Create(CloudUrl + GetDeviceCommand + id.ToString()) as HttpWebRequest;
// req.Method = GetMethod;
// WebResponse resp = req.GetResponse();
// Stream stm = resp.GetResponseStream();
// JsonSerializer js = new JsonSerializer();
// return (Device)js.Deserialize(stm, typeof(Device));
/// <summary>
/// Performs an asynchronous request and returns its response
/// </summary>
/// <param name="req">Request to be executed</param>
/// <returns>HTTP response; it can be null in case of an error</returns>
private HttpWebResponse GetResponseAsync(HttpWebRequest req)
HttpWebResponse resp;
//_req = req;
resp = null;
Exception exthread = null;
Thread th = new Thread(() =>
try
resp = (HttpWebResponse)req.GetResponse();
catch (Exception ex)
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " GetResponseAsync(): " + ex.ToString());
exthread = ex;
//_recvEvent.Set();
th.Start();
if (!th.Join(AsyncTimeout))
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " GetResponseAsync() aborting the GetResponse thread on timeout");
th.Abort();
resp = null;
throw new System.Net.WebException("HTTP connection timeout", WebExceptionStatus.Timeout); //InvalidOperationException("Timeout!");
if (resp == null)
if (exthread != null)
throw exthread;
throw new System.Net.WebException("GetResponse failed");
return resp;
private Stream GetRequestStreamAsync( HttpWebRequest req )
Stream rs = null;
try
rs = req.GetRequestStream();
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " GetRequestStreamAsync(): " + ex.ToString());
exthread = ex;
th.Start();
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " GetRequestStreamAsync() aborting the GetRequestStream thread on timeout");
th.Abort();
rs = null;
if (rs == null)
throw exthread;
return rs;
private WebResponse MakeRequest(string url, object obj, string Method, string id, string key)
StringBuilder headers = new StringBuilder();
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " Request: " + url);
using (HttpWebRequest req = HttpWebRequest.Create(url) as HttpWebRequest)
req.Method = Method;
req.ContentType = ContentType;
req.KeepAlive = false;
req.Headers.Add(IdHeader, id);
req.Headers.Add(KeyHeader, key);
req.ReadWriteTimeout = AsyncTimeout;
req.Timeout = AsyncTimeout;
headers.Append(" Method = " + Method);
headers.Append(" ContentType = " + ContentType);
headers.Append(" " + IdHeader + " = " + id);
//headers.Append(" " + KeyHeader + " = " + key);
headers.Append(" Timeout = " + AsyncTimeout.ToString());
if (obj != null)
JsonFormatter js = new JsonFormatter();
string s = js.ToJson(obj);
req.ContentLength = s.Length;
//headers.Append(" ContentLength = " + s.Length);
headers.Append(" Body = " + s);
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + headers.ToString());
Stream rs = GetRequestStreamAsync(req);
if (rs == null)
return (null);
using (rs)
rs.Write(Encoding.UTF8.GetBytes(s), 0, s.Length);
rs.Close();
HttpWebResponse resp = GetResponseAsync(req); //was (HttpWebResponse)req.GetResponse(); //
if (resp != null)
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " Request done. Response code = " + resp.StatusCode.ToString());
return resp;
/// <summary>
/// Gets API info.
/// </summary>
/// <returns><see cref="ApiInfo"/> object.</returns>
public ApiInfo GetApiInfo()
byte[] bts = null;
HttpWebResponse resp = MakeRequest(CloudUrl + InfoCommand, null, GetMethod, null, null) as HttpWebResponse;
if (resp.ContentType.IndexOf(ContentType) >= 0)
if (resp.ContentLength > 0)
using (Stream rs = resp.GetResponseStream())
bts = new byte[(int)rs.Length];
rs.Read(bts, 0, bts.Length);
rs.Close();
resp.Close();
if (bts != null)
object o = js.FromJson(bts, typeof(ApiInfo));
ApiInfo ai = o as ApiInfo;
if (ai != null)
return ai;
throw new Exception("Unknown error while getting ApiInfo.");
/// <summary>
/// Registers a device
/// </summary>
/// <param name="device">Device data structure</param>
/// <returns>True, if registration succeeds; false - otherwise</returns>
/// <remarks>
/// This method is called by device to register it at the server.
/// </remarks>
public bool SetDevice(Device device)
//bool rv = false;
HttpWebResponse resp = MakeRequest(CloudUrl + DeviceCommand + device.id.ToString(),
device,
PutMethod,
device.key) as HttpWebResponse;
return resp.StatusCode == HttpStatusCode.OK || resp.StatusCode == HttpStatusCode.NoContent;
/// <summary>
/// Sends a notification
/// </summary>
/// <param name="device">Device data of the device that is sending the notification</param>
/// <param name="notification">Notification to be sent</param>
/// <returns>True if the notification succeeds; false - otherwise</returns>
/// <remarks>
/// This method can be used by devices to send notifications.
/// </remarks>
public bool PostNotification(Device device, INotification notification)
//bool rv = false;
CloudUrl + DeviceCommand + device.id.ToString() + NotificationCommand,
notification.Data,
PostMethod,
return resp.StatusCode == HttpStatusCode.OK || resp.StatusCode == HttpStatusCode.Created;
//resp.Close();
/// <summary>
/// Polls command for execution
/// </summary>
/// <param name="device">Device data of the device that is polling a command</param>
/// <param name="onlyUnprocessed">Get commands with empty status only</param>
/// <returns>Command data structure or null if there are no commands</returns>
/// <remarks>
/// This method returns the next command from the command queue. If there are no commands in the queue, it waits for ~30 seconds to receive a new command.
/// </remarks>
public DeviceCommand PollCommand(Device device, bool onlyUnprocessed = true)
if (CommandQueue.Count != 0)
return (DeviceCommand)CommandQueue.Dequeue();
string TimeString = UriExtensions.EscapeDataString(LastTimeStamp);
string Url = CloudUrl + DeviceCommand + device.id.ToString() + PollCommandName + TimeString;
byte[] bts = null;
WebResponse resp = MakeRequest(Url, null, GetMethod, device.id.ToString(), device.key);
rs.Close();
try
string strjson = new string(Encoding.UTF8.GetChars(bts));
if ( strjson != "[]" )
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " " + strjson);
Debug.Print("PollCommand() : " + ex.ToString());
resp.Close();
if (bts != null)
object o = js.FromJson(bts, typeof(DeviceCommand));
DeviceCommand dc = o as DeviceCommand;
if (dc != null && (!onlyUnprocessed || StringExtensions.IsNullOrEmpty(dc.status)))
return dc;
ArrayList al = o as ArrayList;
if (al != null)
if (al.Count == 0) return null;
for (int x = 0; x < al.Count; ++x)
dc = (DeviceCommand)al[x];
if (!onlyUnprocessed || StringExtensions.IsNullOrEmpty(dc.status))
CommandQueue.Enqueue(dc);
DeviceCommand ldc = (DeviceCommand)al[al.Count - 1];
LastTimeStamp = ldc.timestamp;
return CommandQueue.Count == 0 ? null : (DeviceCommand)CommandQueue.Dequeue();
return null;
/// <summary>
/// Gets a command
/// </summary>
/// <param name="device">Device data of the device that is getting a command</param>
/// <returns>Command data structure or null if there are no pending commands</returns>
/// <remarks>
/// This method returns all the commands that are waiting at the server since last GetCommand call. It returns immediately, regardless if there are commands to execute or not.
/// </remarks>
public DeviceCommand GetCommand(Device device, bool onlyUnprocessed = true)
string Url = CloudUrl + DeviceCommand + device.id.ToString() + PollCommandName + TimeString + "&waitTimeout=0";
byte[] bts = null;
rs.Close();
resp.Close();
if (bts != null)
return dc;
if (al != null)
return null;
/// <summary>
/// Updates command status
/// </summary>
/// <param name="device">Device data of the device that is updating a command status</param>
/// <param name="CommandId">ID of the command to be updated</param>
/// <param name="status">Status of the command</param>
/// <returns>True if the status update was successfull; false - otherwise</returns>
/// <remarks>
/// The devices are using this method to notify the server of command completion and its result.
/// </remarks>
public bool UpdateCommandStatus(Device device, string CommandId, CommandStatus status)
//bool rv = false;
CloudUrl + DeviceCommand + device.id.ToString() + CommandStatus + CommandId,
status,
PutMethod,
