Anyone have a camera ( https://www.ghielectronics.com/catalog/product/283 ) working with a raptor as I’m getting the following error.
A first chance exception of type ‘System.ArgumentException’ occurred in mscorlib.dll
Error invoking method “Gadgeteer.Modules.GHIElectronics.Camera” (check arguments to Program.BeginInvoke are correct)
This occurs after I try to take a picture
if (camera.CameraReady)
camera.TakePicture();
That’s funny, because we know that BeginInvoke is not implemented in NETMF. It’s there, but you can not even decompile the method.
@ Reinhard Ostermeier - I think you are confusing Delegate.BeginInvoke with Dispatcher.BeginInvoke. Delegate.BeginInvoke is not implemented, but .NETMF has a Dispatcher which is primarily used to marshal calls across threads and it has a method called BeginInvoke, this is similar to the desktop Framework.
Other then a couple of minor quibbles, like this, I think I have found myself a new favorite board as this Raptor is a brute looking for a place to happen. I’m loading this sucker up and it just mashes the tasks I’m giving it.
Another issue would be how do I get the IP Address from a wifi connection so I can setup a webserver on the raptor as there doesn’t appear to be wifi_RS21.Interface.NetworkInterface.IPAddress
@ Duke Nukem - Make a little server on PC. Connect from Raptor and check the incoming IP.
What I need is the IP Address of the Wifi connection on the Raptor so I can do this:
_showData = WebServer.SetupWebEvent("index.html");
_showData.WebEventReceived += _showData_WebEventReceived;
WebServer.StartLocalServer(Whatever my IPAddress is, 80);
Just trying to build up a Gadgeteer Demo that shows off a pile of Gadgeteer features, including @ Justin RF Pipes ( https://www.ghielectronics.com/community/creations/entry/12 ) as those are so freaking easy to use, even I got them going on the first crack.
@ Duke Nukem - At what point in your code are you calling camera.TakePicture()? If you are calling it in ProgramStarted, then the Gadgeteer framework is not completely initialized.
Try firing the call in a timer that triggers sometime after ProgramStarted has completed.
The code below worked for me on my Raptor.
using GT = Gadgeteer;
namespace Raptor1
public partial class Program
GT.Timer _timer;
_timer = new GT.Timer(1000);
_timer.Tick += _timer_Tick;
_timer.Start();
camera.PictureCaptured += camera_PictureCaptured;
void camera_PictureCaptured(Camera sender, GT.Picture picture)
display_T35.SimpleGraphics.DisplayImage(picture, 0, 0);
void _timer_Tick(GT.Timer timer)
@ taylorza thanks the bug was in my code in the camera_PictureCaptured routine around how I was trying to create a filename so save the picture with, so its my bad. I should have put a breakpoint in the routine when I first saw the error and it would have shown me what the problem was, I incorrectly assumed the error was in the call to take the picture, but really it was my code in the saving of the picture.
@ Duke Nukem - Well, it gave me an excuse to finally connect my new Raptor
