I have issues with using a radio button with Glide 1.0.0:
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (1) ####
#### Message:
#### GHIElectronics.NETMF.Glide.UI.RadioButton::Render [IP: 0008] ####
#### GHIElectronics.NETMF.Glide.Display.DisplayObject::Invalidate [IP: 0005] ####
#### GHIElectronics.NETMF.Glide.UI.RadioButton::set_IsSelected [IP: 0016] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::LoadRadioButton [IP: 00ca] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::GetComponent [IP: 00a6] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::LoadWindow [IP: 00a9] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::LoadWindow [IP: 000b] ####
Window is:
<Glide Version="1.0.0">
<Window Name="instance115" Width="320" Height="240" BackColor="FFFFFF">
<RadioButton Name="staticRB" X="10" Y="10" Width="32" Height="32" Alpha="255" Value="static" IsSelected="True" GroupName="IPType" ShowBackground="True" Color="d4d4d4" OutlineColor="b8b8b8" SelectedColor="358bf6" SelectedOutlineColor="002dff"/>
<RadioButton Name="dhcpRB" X="142" Y="10" Width="32" Height="32" Alpha="255" Value="DHCP" IsSelected="False" GroupName="IPType" ShowBackground="True" Color="d4d4d4" OutlineColor="b8b8b8" SelectedColor="358bf6" SelectedOutlineColor="002dff"/>
<Button Name="okBtn" X="122" Y="198" Width="80" Height="32" Alpha="255" Text="OK" Font="4" FontColor="000000" DisabledFontColor="808080" TintColor="000000" TintAmount="0"/>
</Window>
</Glide>
Code is:
static Window windowMain;
static Window windowNet;
LCDSettings.SetBootSetup();
// Load the window
windowMain = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.MainWindow));
windowNet = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.NetWindow));
// Activate touch
GlideTouch.Initialize();
// Initialize the window.
windowMainInit();
windowNewInit();
// Assigning a window to MainWindow flushes it to the screen.
// This also starts event handling on the window.
Glide.MainWindow = windowMain;
Exception occurs on line:
Any ideas? If I remove the first row it displays - but with a radiobutton missing.
Thanks!
