I use a button and a Cellular for a simple test.
When GSM and GPRS network connected, I press button to send a sms and send a request to www.google.com.
My questions are:
I can’t get IP address each time. I need rebuild the application many times then get the IP address. How to set the module to reconnect the GPRS to get the IP, instead of rebooting the system?
The debug output shows Exception below
Exception System.Exception - 0x00000000 (4)
#### Message:
#### System.Convert::ToInt64 [IP: 00af] ####
#### System.Convert::ToInt32 [IP: 0011] ####
#### System.Int32::Parse [IP: 000b] ####
#### Gadgeteer.Modules.Mekalogic.CellularRadio::ProcessATCommandResponse [IP: 01bd] ####
#### Gadgeteer.Modules.Mekalogic.CellularRadio::SerialRead [IP: 0030] ####
A first chance exception of type ‘System.Exception’ occurred in mscorlib.dll
- When I see the Ip in the output window, I press the button.
After the button is pressed, the system hangs.
However the sms successfully send to my phone.
private CellularRadioManager _radioManager;
GT.Timer GPRStimer;
GPRStimer = new GT.Timer(2000); // every second (1000ms);
GPRStimer.Tick += GPRStimer_Tick;
button.ButtonPressed+=button_ButtonPressed;
//GPRStimer.Start();
_radioManager = new CellularRadioManager(4)
AccessPointName = "internet",
DebugPrintEnabled = true,
IsHttpModeEnabled = true
private readonly string _crlf = "" + (char)13 + (char)10;
void button_ButtonPressed(Button sender, Button.ButtonState state)
Debug.Print("test");
_radioManager.SendSMS("0963354403", "Scouring on Bridge1");
_radioManager.Connect("www.google.com");
var request =
"GET / HTTP/1.1" + _crlf +
"Host: www.google.com" + _crlf +
_crlf;
_radioManager.SendData(request);
var response = "";
_radioManager.ReceiveData(5000, out response);
Debug.Print(response);
Debug.Print("finished");
output:
Program Started
#### Exception System.Exception - 0x00000000 (4) ####
#### Message:
GSM Network Registration Error
The thread ‘’ (0x6) has exited with code 0 (0x0).
#### Message:
GSM Network Registered
GPRS Network Registration Error
GPRS Network Registered
IMEI: 861785000232458
IP: 116.59.177.15
test
