-Now create a new project of type NetMF console application.
-Add referenece and using statement for the library.
-Use Program.Main method of the application project for your web server app.
Wouter’s code has an example on how to use his library.
I want to find a example about dada access between “EMX” and “http webbrowser”. I really want to know how can I monitor information( live data) on my board via the browser.
The example looks like pass me, so I want to try the example.
@ workhard: You cannot run the example out of the box, as it is missing a project file, there’s no solution and there are no using statemens in the top of the example file.
So a little work (no hard work however ) is needed at your side. Create a new project for your hardware. Try to get that running first…
Then right-click your solution in the “Solution explorer” and click “Add” > “Existing project”, then head to the “FastloadMedia.NETMF.csproj” file. Then right-click on your created project and choose “Add reference…”, click the “Projects” tab and select the “FastloadMedia.NETMF” library. Now in your project code type “HttpServer”, right-click on that word and choose “Resolve” > “using FastloadMedia.NETMF”.
Once you have that, check the Example.cs file and extract what you need.
