Question about text justifying in netmf
I have a string that is 16 characters wide and I need to right justify the text in it… Usually I would just use string.Format but netmf doesnt have that…
Any ideas on how to do this?
This is “micro” framework so it doesn’t have everything you see in full .NET. You may need to do those little things manually.
Any idea how I can do this “manually”?
Try this:
String field = "ABCD        ";
field = field.Trim();
field = new String(' ', 16 - field.Length) + field;
Awesome, worked perfectly… Now my FEZ lcd/keypad shield has scrolling text running in separate threads… Thanks for your help…
