This is the code example from GHI.
I have couple questions as I couldn’t find any other documentation.
- Do I need to use pull down resistor for SignalGenerator pin?
- What are the time array elements represent? Is the first element duration for pin to be in ON state and second element is duration for the pin OFF?
uint[] time = new uint[] { 500 * 1000, 500 * 1000 };
SignalGenerator LED = new SignalGenerator(Cpu.Pin.GPIO_Pin1, false);
// args: initial value,
// array of times,
// array start offset,
// length of array,
// repeat -- if true ==> repeat
LED.Set(false, time, 0, 2, true);//start the waveform
//... do more code here and the LED will continue to work.
//... because the default running mode is non-blocking.
