i would like the variable xyz to be avaialble at all levels, but this does not appear to be happening, even though it is defined in a public section…what is wrong here? I get the error: the name xyz does not exist not in this context …is there a fix?
// This will hold the main window.
static Window window;
GlideTouch.Initialize();
string xyz = "";
InitWin();
static void btn_Releaseit(object sender)
xyz = "testing"; //error the name xyz does not exist not in this context
static void btn_PressIt(object sender)
xyz = "here it is"; //error the name xyz does not exist not in this context
static void InitWin()
///code
