I am trying the Pyxis2 OE out on my FEZ Cobra. I cannot get the project to deploy correctly to the device. Obviously I am missing something, I just dont know what is it.
I am following the steps in the Pyxis2UserGuide.pdf. On the FEZ Cobra I have the follow versions:
- TinyBooter Version: 4.1.6.0
- Firmware Version: 4.1.7.0
- Startup project needs to be Pyxis2 not Kernel
- You need to delete and replace all the GHI references (this will bring them up to date)
- The replacement for Pyxis 2 (Gadgetos) is coming out soon.
Edit: Alternatively you should be able to delete all the bin/obj directories (with the project closed) and have them automatically update when you reopen the solution.
Thanks, that did the trick deleting the references.
