please can you tell me the maximum frequency for the PWM ports and the PWM resolution I can get?
As I can see, the duty cycle parameter is byte, the resolution is limited to ~0.4%, is this right?
I need a base frequency from about 250kHz minimum, is this possible?
As the processor is clocked with 75MHz, this should be possible.
Thanks for helping.
With best regards
Gerhard
PS: The Brochure and the other text books should contain such limits, this information is vital for engeneers trying to use this stuff in valuable systems or end user products.
