Hi. Which module should we purchase for motors that required PWM? The motor module seems to be formatted for standard DC motors. Thanks.
What type and size of motor?
All boards have built in PWM and you can add IO60P16 module to give 16 more PWM and 60 more IOs.
We are looking at a standard Parallax continuous rotation servo. Here is the link:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/motors/List/0/SortField/4/catpageindex/3/ProductID/102/Default.aspx
Is there a specific link for that part?
Thanks.
I found the link. Thanks!
Yes that module will work and you can also connect the servos directly using extender module
