Aron, EXCELLENT explanation thank you! It clarify s what I said above.
This is how it should have been explained and yes it needs to be in the Developers Guide, this is essential information for many when planning projects.
For many, PWM is useless unless the frequency can be changed!
Realistically, any situation where a Timer is shared, it should not be classed as PWM, instead maybe as Shared PWM because this is not true PWM as there is no ‘Modulation’ component to fixed frequency DC Pulses as Duty Cycle is proportional to Frequency.
Ref: Pulse-width modulation - Wikipedia
This means that the Cerberus Specs should read:
PWM = 4 (Pin 8 on X3, Pin 9 on X3, Pin 7 on X4, Pin 9 on X4)
Shared PWM = 2 ((Pin 7 on X3 shared with Pin 8 on X3) (Pin 8 on X4 shared with Pin 9 on X4))
Thanks again Aron.
All the Best
Chris
