I have a Pulse Oximeter that I tested on a Fez Hydra and now I am trying to get it working on a ChipworkX dev board.
I have it sort of working by porting the code from Seed Studio but it is just not stable and I don’t get the same clean readings as on the Hydra. In fact, it never shows detatched at all.
I have added code to extract the PulseWave readings and display these on the LCD. It is all over the place when running without a finger in the sensor.
I see from the manual on the device there are some settings and I have tried various gain settings etc but nothing gives me the same clean reading as on the Hydra and Gadgeteer.
Does the Gadgeteer driver do anything in regards to settings? I don’t see any on the Seeed code I downloaded today.
Anyone else got this to work in this manner?
OK. I got this working.
It is basically that the unit takes a little while to stabilise and auto adjust the sensor settings etc.
By the way, although use shows with a finger, I have found a much stronger reading is obtained from your thumb.
I have it working on a ChipworkX board and once I return home from vacation, I will test with a Hydra and once I have it working, I’ll post the code for others to have a play with.
The interesting part is the inclusion of he PulseWave readings and display of this on a bitmap image, you can see nicely the auto gain working and a steady stream of pulses gives you a good indication that the readings are now stable enough to be valid.
Glad you got it going.
@ GHI - I was just looking over the product description of this module. I think you have some typos…
Correct me if I’m wrong, but I think “heat” is supposed to be “heart”. Pretty big difference
@ ianlee74 - fixed, thanks!
