Hi Everyone,
I have some code working, actually it was a bit more of a task than first thought. I have used the Datasheet and to my understanding have the code right but I seem to be striking two seperate problems:
1: It takes about a minute after reboot to work. EG: I get no output on my Pins untill around a minute or so, then the PWM works fine.
2: The Pins i have selected in the Register (PINSEL3) are not the Pins that they should be?
3: There is at higher frequencys a little bit of distortion in the wave form. According to all I have read this is normal behavior.
Here is my Code:
using GHIElectronics.NETMF.Hardware.LowLevel;
namespace FEZ_Panda_II_HardWarePWM
// Please do not remove this header... //
// This Code is Copyrighted under the Apache 2.0 Licence. //
// http://www.apache.org/licenses/LICENSE-2.0.txt //
// Written by Chris Sykes (ChrisO) //
// For use by all FEZ Panda II Users.. //
public class HardWarePWM
/// <summary>
/// Primary Frequency of the PWM - The Frequency is set by Match Register 0 (MR0) and can be Single Edge or Double Edge Control Mode set in the PWM Control Registers (PWM1PCR)...
/// See Page 562 of LPC23XX User Manual : Chapter 24: LPC23XX Pulse width modulator Rev. 02 — 11 February 2009...
/// </summary>
private static uint _frequency;
/// <summary>
/// Match Register 1 (MR1) Duty Cycle in Percent...
/// </summary>
private static uint _dutyMR1;
/// <summary>
/// Match Register 2 (MR2) Duty Cycle in Percent...
/// </summary>
private static uint _dutyMR2;
/// <summary>
/// Match Register 3 (MR3) Duty Cycle in Percent...
/// </summary>
private static uint _dutyMR3;
/// <summary>
/// Match Register 4 (MR4) Duty Cycle in Percent...
/// </summary>
private static uint _dutyMR4;
/// <summary>
/// Match Register 5 (MR5) Duty Cycle in Percent...
/// </summary>
private static uint _dutyMR5;
/// <summary>
/// Match Register 6 (MR6) Duty Cycle in Percent...
/// </summary>
private static uint _dutyMR6;
/// <summary>
/// Set Latch Enable Register Bits for the corrosponding Match Register's...
/// </summary>
/// <param name="bit">
/// A 7 Bit Array, value's 0 - 6 must be set 0 or 1 :
/// Bit 0 Enable PWM Match 0 Latch
/// Bit 1 Enable PWM Match 1 Latch
/// Bit 2 Enable PWM Match 2 Latch
/// Bit 3 Enable PWM Match 3 Latch
/// Bit 4 Enable PWM Match 4 Latch
/// Bit 5 Enable PWM Match 5 Latch
/// Bit 6 Enable PWM Match 6 Latch
/// For example, if the PWM is configured for double edge operation and is currently running,
/// a typical sequence of events for changing the timing would be:
/// • Write a new value to the PWM Match1 register.
/// • Write a new value to the PWM Match2 register.
/// • Write to the PWMLER, setting bits 1 and 2 at the same time.
/// • The altered values will become effective at the next reset of the timer (when a PWM Match 0 event occurs).
/// </param>
private static void SetLatchEnableRegister(byte[] bit)
// PWM Latch Enable Register (PWM1LER - 0xE001 8050)
// See Page: 575 - LPC23XX User Manual Rev. 02 — 11 February 2009...
Register PWM1LER = new Register(LPC23xx.PWM1LER);
if (bit[0] == 1) PWM1LER.SetBits(1 << 0);
if (bit[1] == 1) PWM1LER.SetBits(1 << 1);
if (bit[2] == 1) PWM1LER.SetBits(1 << 2);
if (bit[3] == 1) PWM1LER.SetBits(1 << 3);
if (bit[4] == 1) PWM1LER.SetBits(1 << 4);
if (bit[5] == 1) PWM1LER.SetBits(1 << 5);
if (bit[6] == 1) PWM1LER.SetBits(1 << 6);
/// <summary>
/// PWM Setup, Initialise a PWM Setup...
/// This section is described in Chapter 24: LPC23XX Pulse width modulator...
/// See Page: 562 - LPC23XX User manual Rev. 02 — 11 February 2009...
/// _______________________________________________________________________________________________________
/// Basic Setup :
/// The PWM is configured using the following registers:
/// 1. Power: In the PCONP register (Table 4–56), set bit PCPWM1.
/// Remark: On reset, the PWM is enabled (PCPWM1 = 1).
/// 2. Peripheral clock: In the PCLK_SEL0 register (Table 4–49), select PCLK_PWM.
/// 3. Pins: Select PWM pins and pin modes in registers PINSELn and PINMODEn (see Section 9–5).
/// 4. Interrupts: See register PWM1MCR (Table 24–487) and PWM1CCR (Table 24–488) for match and capture events.
/// Interrupts are enabled in the VIC using the VICIntEnable register (Table 6–76).
/// This implementation supports up to N-1 single edge PWM outputs or (N-1)/2 double edge
/// PWM outputs, where N is the number of match registers that are implemented. PWM
/// types can be mixed if desired.
/// </summary>
public static void Setup()
#region Power: In the PCONP register (Table 4–56), set bit PCPWM1.
// Power Control for Peripherals Register (PCONP - 0xE01F C0C4)
// See Page: 68 - LPC23XX User manual Rev. 02 — 11 February 2009...
//_______________________________________________________________________________________________________
// Bit Symbol Description Reset value
// 6 PCPWM1 PWM1 power/clock control bit. 1
Register PCONP = new Register(LPC23xx.PCONP);
PCONP.SetBits(1 << 6);
#endregion
#region Peripheral clock: In the PCLK_SEL0 register (Table 4–49), select PCLK_PWM.
// Peripheral Clock Selection registers 0 and 1 (PCLKSEL0 - 0xE01F C1A8 and PCLKSEL1 - 0xE01F C1AC)
// See Page: 62 - LPC23XX User manual Rev. 02 — 11 February 2009...
// A pair of bits in a Peripheral Clock Selection register controls the rate of the clock signal
// that will be supplied to the corresponding peripheral as specified in Table 4–49, Table 4–50 and Table 4–51.
//______________________________________________________________________________________________________________________________
// 13:12 PCLK_PWM1 Peripheral clock selection for PWM1.
// See Page: 63 - LPC23XX User manual Rev. 02 — 11 February 2009 : Table 51. Peripheral Clock Selection register bit values
// 00 PCLK_xyz = CCLK/4
// 01 PCLK_xyz = CCLK[1]
// 10 PCLK_xyz = CCLK/2
// 11 Peripherals clock is selected to PCLK_xyz = CCLK/8 except for CAN1, CAN2, and CAN filtering when 11 selects PCLK_xyz = CCLK/6.
Register PCLKSEL0 = new Register(LPC23xx.PCLKSEL0);
PCLKSEL0.ClearBits(3 << 12);
PCLKSEL0.SetBits(1 << 12);
#endregion
// TODO WORK OUT Why my Pin Setup does not work as per Pin Out on FEZ Panda II Schematic...
#region Pins: Select PWM pins and pin modes in registers PINSELn and PINMODEn (see Section 9–5).
// Pin function select register 3 (PINSEL3 - address 0xE002 C00C) bit description (LPC2361/62/64/65/66/67/68 and LPC2387)
// See Page: 160 - LPC23XX User manual Rev. 02 — 11 February 2009...
// PINSEL3 Pin name Function when 00 Function when 01 Function when 10 Function when 11 Reset value
// 5:4 P1.18 GPIO Port 1.18 USB_UP_LED1[1] PWM1.1 CAP1.0 00 - IO35 on the FEZ Panda II...
// 9:8 P1.20 GPIO Port 1.20 USB_TX_DP1[2] PWM1.2 SCK0 00 - IO25 on the FEZ Panda II...
// 11:10 P1.21 GPIO Port 1.21 USB_TX_DM1[2] PWM1.3 SSEL0 00 - IO23 on the FEZ Panda II...
// 15:14 P1.23 GPIO Port 1.23 USB_RX_DP1[2] PWM1.4 MISO0 00 - IO62 on the FEZ Panda II...
// 17:16 P1.24 GPIO Port 1.24 USB_RX_DM1[2] PWM1.5 MOSI0 00 - IO63 on the FEZ Panda II...
// 21:20 P1.26 GPIO Port 1.26 USB_SSPND1[2] PWM1.6 CAP0.0 00 - IO65 on the FEZ Panda II...
// Pin function select register 4 (PINSEL4 - address 0xE002 C010) bit description (LPC2364/65/66/67/68 and LPC2387)
// See Page: 161 - LPC23XX User manual Rev. 02 — 11 February 2009...
// PINSEL4 Pin name Function when 00 Function when 01 Function when 10 Function when 11 Reset value
// 1:0 P2.0 GPIO Port 2.0 PWM1.1 TXD1 TRACECLK[1] 00 - IO05 on the FEZ Panda II...
// 3:2 P2.1 GPIO Port 2.1 PWM1.2 RXD1 PIPESTAT0[1] 00 - IO03 on the FEZ Panda II...
// 5:4 P2.2 GPIO Port 2.2 PWM1.3 CTS1 PIPESTAT1[1] 00 - IO01 on the FEZ Panda II...
// 7:6 P2.3 GPIO Port 2.3 PWM1.4 DCD1 PIPESTAT2[1] 00 - IO04 on the FEZ Panda II...
// 9:8 P2.4 GPIO Port 2.4 PWM1.5 DSR1 TRACESYNC[1] 00 - IO02 on the FEZ Panda II...
// 11:10 P2.5 GPIO Port 2.5 PWM1.6 DTR1 TRACEPKT0[1] 00 - IO07 on the FEZ Panda II...
Register PINSEL3 = new Register(LPC23xx.PINSEL3);
PINSEL3.SetBits(2 << 4);
PINSEL3.SetBits(2 << 8);
PINSEL3.SetBits(2 << 10);
PINSEL3.SetBits(2 << 14);
PINSEL3.SetBits(2 << 16);
PINSEL3.SetBits(2 << 20);
// 0x0228A23 is the Hex Equivilent...
// Pin Mode select register 1 (PINMODE1 - 0xE002 C044)
// See Page: 167 - LPC23XX User manual Rev. 02 — 11 February 2009...
// 00 Pin has an on-chip pull-up resistor enabled.
// 01 Reserved. This value should not be used.
// 10 Pin has neither pull-up nor pull-down resistor enabled.
// 11 Pin has an on-chip pull-down resistor enabled.
// PINMODE1 Symbol Description Reset value
// 1:0 P1.16MODE PORT1 pin 16 on-chip pull-up/down resistor control. 00
// 31:30 P1.31MODE PORT1 pin 31 on-chip pull-up/down resistor control. 00
// PINMODE0 to PINMODE9 Values Function Value after Reset
// 00 Pin has an on-chip pull-up resistor enabled. 00
Register PINMODE3 = new Register(LPC23xx.PINMODE3);
PINMODE3.SetBits(3 << 0);
PINMODE3.SetBits(3 << 20);
#endregion
#region Interrupts: See register PWM1MCR (Table 24–487) and PWM1CCR (Table 24–488) for match and capture events. Interrupts are enabled in the VIC using the VICIntEnable register (Table 6–76).
// PWM Match Control Register (PWM1MCR - 0xE001 8014)
// See Page: 570 - LPC23XX User manual Rev. 02 — 11 February 2009...
// The PWM Match Control Registers are used to control what operations are performed
// when one of the PWM Match Registers matches the PWM Timer Counter. The function of
// each of the bits is shown in Table 24–487.
Register PWM1MCR = new Register(LPC23xx.PWM1MCR);
// Enable the Timer - Set Bit 2 to 1...
PWM1MCR.SetBits(1 << 1);
// Set the match Register 0 to a value of 0...
Register PWM1MR0 = new Register(LPC23xx.PWM1MR0);
PWM1MR0.Write(0);
#endregion
#region Configure the PWM Control Registers (PWM1PCR)...
// PWM Control Registers (PWM1PCR - 0xE001 804C)
// See Page: 573 - LPC23XX User manual Rev. 02 — 11 February 2009...
// The PWM Control Registers are used to enable and select the type of each PWM
// channel. The function of each of the bits are shown in Table 24–489.
// _______________________________________________________________________________________________________________________________
// Bit Symbol Value Description Reset Value
// 1:0 Unused Unused, always zero. NA
// 2 PWMSEL2 1 Selects double edge controlled mode for the PWM2 output. 0
// 0 Selects single edge controlled mode for PWM2.
// 3 PWMSEL3 1 Selects double edge controlled mode for the PWM3 output. 0
// 0 Selects single edge controlled mode for PWM3.
// 4 PWMSEL4 1 Selects double edge controlled mode for the PWM4 output. 0
// 0 Selects single edge controlled mode for PWM4.
// 5 PWMSEL5 1 Selects double edge controlled mode for the PWM5 output. 0
// 0 Selects single edge controlled mode for PWM5.
// 6 PWMSEL6 1 Selects double edge controlled mode for the PWM6 output. 0
// 0 Selects single edge controlled mode for PWM6.
// 8:7 - Reserved, user software should not write ones to reserved bits.
// The value read from a reserved bit is not defined.
// 9 PWMENA1 1 The PWM1 output enabled. 0
// 10 PWMENA2 1 The PWM2 output enabled. 0
// 11 PWMENA3 1 The PWM3 output enabled. 0
// 12 PWMENA4 1 The PWM4 output enabled. 0
// 13 PWMENA5 1 The PWM5 output enabled. 0
// 14 PWMENA6 1 The PWM6 output enabled. 0
// It is generally not advantageous to use PWM channels 3 and 5 for double edge PWM outputs because it
// would reduce the number of double edge PWM outputs that are possible. Using PWM 2, PWM4, and
// PWM6 for double edge PWM outputs provides the most pairings.
Register PWM1PCR = new Register(LPC23xx.PWM1PCR);
PWM1PCR.Write(0x00);
// Reserved Bits Dont Change this: PWM1PCR.ClearBits(3 << 7);
PWM1PCR.SetBits(1 << 9);
PWM1PCR.SetBits(1 << 10);
PWM1PCR.SetBits(1 << 11);
PWM1PCR.SetBits(1 << 12);
PWM1PCR.SetBits(1 << 13);
PWM1PCR.SetBits(1 << 14);
#endregion
// Optional - Set PR, IR and CTCR Registers...
ZeroValueRegisters();
#region Set the Latch Enable Register Settings....
// See the SetLatchEnableRegister method Description Above...
byte[] bit = { 1, 0, 0, 0, 0, 0, 0 };
SetLatchEnableRegister(bit);
#endregion
#region Enable the Timer Control Register (PWM1TCR) Enable the Timer and PWM Mode...
// Enable the Timer Control Register (PWM1TCR) Enable the Timer and PWM Mode...
Register PWM1TCR = new Register(LPC23xx.PWM1TCR);
PWM1TCR.Write(0x09U);
#endregion
/// <summary>
/// Typically this section is not needed as the Values are already what we need... All 0...
/// You can call this methods if you need to...
/// </summary>
private static void ZeroValueRegisters()
// Prescale Register (PWM1PR - 0xE001 800C)
// See Page: 567 - LPC23XX User manual Rev. 02 — 11 February 2009...
// The TC is incremented every PR+1 cycles of PCLK.
Register PWM1PR = new Register(LPC23xx.PWM1PR);
PWM1PR.Write(0);
// PWM Interrupt Register (PWM1IR - 0xE001 8000)
// See Page: 568 - LPC23XX User manual Rev. 02 — 11 February 2009...
Register PWM1IR = new Register(LPC23xx.PWM1IR);
PWM1IR.Write(0);
// PWM Count Control Register (PWM1CTCR - 0xE001 8070)
// See Page: 569 - LPC23XX User manual Rev. 02 — 11 February 2009...
Register PWM1CTCR = new Register(LPC23xx.PWM1CTCR);
PWM1CTCR.Write(0);
/// <summary>
/// Set the Pin Number, the base Frequency and the Duty Cycle of the PWM...
/// </summary>
/// <param name="Pin">int - PWM Pins 1 - 6</param>
/// <param name="Frequency">double - Frequency in Hz. Clock is 72Mhz.</param>
/// <param name="DutyCycle">int - Values 0 - 100 are valid Duty Cycle values.</param>
public static void SetPWM(int Pin, double Frequency, int DutyCycle)
// Check Input from User...
if (Frequency >= 1 && Frequency <= 72000000)
// Set Frequency in Hz...
_frequency = (uint)(72000000 / Frequency);
PWM1MR0.Write(_frequency);
switch (Pin)
case 1:
SetPWM1Duty(DutyCycle);
break;
case 2:
SetPWM2Duty(DutyCycle);
break;
case 3:
SetPWM3Duty(DutyCycle);
break;
case 4:
SetPWM4Duty(DutyCycle);
break;
case 5:
SetPWM5Duty(DutyCycle);
break;
case 6:
SetPWM6Duty(DutyCycle);
break;
default:
Debug.Print("Invalid selection. Please select 1, 2, or 3.");
break;
/// <summary>
/// Calculate Duty Percentage - User Inputs say 50, which will be a percentage of the Frequency that has been selected...
/// This sets the Duty Cycle of the Frequency to a value of 50%, so 50% on and 50% off in one cycle...
/// </summary>
/// <param name="percentage"></param>
/// <returns></returns>
private static uint CalculateDutyPercentage(double percentage)
// Calculate the Percentage Divider...
double devider = (percentage / 100.0);
// Calculate the Percentage of the Frequency...
double dutyCycle = (((double)_frequency) * devider);
// Return the calculated Duty Cycle...
return (uint)dutyCycle;
/// <summary>
/// Set the PWM Duty Cycle on PWM1 - Di10 on the FEZ PandaII...
/// </summary>
/// <param name="dutyCyclePercentage">Duty Cycle Example (0 - 100)</param>
private static void SetPWM1Duty(int dutyCyclePercentage)
_dutyMR1 = CalculateDutyPercentage(dutyCyclePercentage);
// Set the Match 1 Register...
Register PWM1MR1 = new Register(LPC23xx.PWM1MR1);
PWM1MR1.Write(_dutyMR1);
// Set the Latch Enable Register...
byte[] bit = { 1, 1, 0, 0, 0, 0, 0 };
/// <summary>
/// Set the PWM Duty Cycle on PWM2 - Di9 on the FEZ PandaII...
/// </summary>
private static void SetPWM2Duty(int dutyCyclePercentage)
_dutyMR2 = CalculateDutyPercentage(dutyCyclePercentage);
// Set the Match 2 Register...
Register PWM1MR2 = new Register(LPC23xx.PWM1MR2);
PWM1MR2.Write(_dutyMR2);
byte[] bit = { 1, 0, 1, 0, 0, 0, 0 };
/// <summary>
/// Set the PWM Duty Cycle on PWM3 - Di8 on the FEZ PandaII...
/// </summary>
private static void SetPWM3Duty(int dutyCyclePercentage)
_dutyMR3 = CalculateDutyPercentage(dutyCyclePercentage);
// Set the Match 3 Register...
Register PWM1MR3 = new Register(LPC23xx.PWM1MR3);
PWM1MR3.Write(_dutyMR3);
byte[] bit = { 1, 0, 0, 1, 0, 0, 0 };
/// <summary>
/// Set the PWM Duty Cycle on PWM4 - Di10 on the FEZ PandaII...
/// </summary>
private static void SetPWM4Duty(int dutyCyclePercentage)
_dutyMR4 = CalculateDutyPercentage(dutyCyclePercentage);
// Set the Match 4 Register...
Register PWM1MR4 = new Register(LPC23xx.PWM1MR4);
PWM1MR4.Write(_dutyMR4);
byte[] bit = { 1, 0, 0, 0, 1, 0, 0 };
/// <summary>
/// Set the PWM Duty Cycle on PWM5 - Di5 on the FEZ PandaII...
/// </summary>
private static void SetPWM5Duty(int dutyCyclePercentage)
_dutyMR5 = CalculateDutyPercentage(dutyCyclePercentage);
// Set the Match 5 Register...
Register PWM1MR5 = new Register(LPC23xx.PWM1MR5);
PWM1MR5.Write(_dutyMR5);
byte[] bit = { 1, 0, 0, 0, 0, 1, 0 };
/// <summary>
/// Set the PWM Duty Cycle on PWM6 - Di6 on the FEZ PandaII...
/// </summary>
private static void SetPWM6Duty(int dutyCyclePercentage)
_dutyMR6 = CalculateDutyPercentage(dutyCyclePercentage);
// Set the Match 6 Register...
Register PWM1MR6 = new Register(LPC23xx.PWM1MR6);
PWM1MR6.Write(_dutyMR6);
byte[] bit = { 1, 0, 0, 0, 0, 0, 1 };
} // END of Class...
} // END of Namespace...
To call my code and make it all work use this:
// Disable Garbage Collection...
// Set a Frequency Variable...
double frequency = 1;
// Setup PWM Registers...
HardWarePWM.Setup();
// Increment the Frequency...
frequency++;
// Set the Frequency and Duty...
HardWarePWM.SetPWM(2, frequency, 50);
// Sleep for 10 milliseconds...
Thread.Sleep(10);
This code works perfectly except for the above problems. Theoretically we should be able to set Frequencys from 1Hz to 72MHz - It seems to be a bit slow at High Frequencys and I need to do more testing on this. It seems to me that the PWM Class in the in the GHI SDK is implimented in a slightly different way. I believe my Code has some advantages over the PWM Class. The Wave form is much cleaner at low frequencys and various other things. Maybe Gus can eloborate on the differences more?
Please let me know if you spot any problems in this code. It is excessively commented - alot of code in the CodeShare and this forum is not very well commented at all and thats good for the experienced but hopeless for the not so much experienced…
This code is in the early stages and may be changed soon due to a few small limitations in the PWM…
ChrisO
