I’m looking for a good source for small pulleys & belts to connect to a NEMA 17 stepper. Any suggestions?
Also, if you have experience with any software to generate the designs to laser cut sprockets that will work with the belt from plexiglass. Links & experiences appreciated.
Thanks guys. I ended up ordering from sdp-si.com. The prices didn’t seem to be that unreasonable for a small quantity order and they were the only site that had enough selection that I could get the sizes I needed. I just took a look at polybelt.com to try and compare prices but they don’t seem to carry the sizes I need either.
I got the belt and some pulleys. They are nice quality.
The next thing I need to do is to create a timing belt pulley design that can be laser cut from acrylic that will match the 2mm pitch belt I bought. Does anyone know of software I can give the pitch and diameter to and have it create the pulley design? Is 2mm pitch too fine for laser cut acrylic?
Neither of those products have a very hobbyist friendly price tag I guess I’ll be drawing it by hand in Sketchup.
I just found this Sketchup Plugin that might do the job. It doesn’t quite give me the kind of control I want. It appears to be made more for gears than timing belt pulleys but it might work.
Take a look at: http://www.gearotic.com/ . I don’t remember if it has timing pulleys built in or not. I have used it to produce some wild elliptical gears though.
