Forgive me if this is a dumb question - I’m pretty new to this newfangled hardware trickery.
I’m trying to get a PS/2 keyboard working with my Panda II. Originally I was using interrupts in C# but it appears they’re too slow, so I’m now developing an RLP module for it.
PS/2 uses a “packet” size of 11 bits - so I should see 11 interrupts with the following whenever I press down on a key (and then multiples of 11 on releasing the key etc):
Weird thing is, I seem to get exactly 6 interrupts per packet. I’ve tried with two keyboards and it does exactly the same thing - 6 interrupts per packet. (I made the ISR simply increase a counter and added a function to retrieve the counter value.)
Start simple, enable a pin with interrupt edge low and then your ISR will only contain variable++
Then there is another RLP to read “variable”
If it doesn’t work then do this:
enable interrupt on the clock pin
once inside the ISR, stay there to read all 11 bits
exit ISR
Note that you are reading a clock that is changing every about 30 microsoceonds so you should read the pin directly instead of using RLP extensions. Make a pin input and ready inside C# but then read the pin directly from the processor.
my_pin = (IOxPIN&(1<<pin)>0);// x is the port and pin is the pin on that port. You need the schematics to determine the port/pin that is related to the NETMF IO you are using.
Another option?
Open SPI in 11 bit more in RLP and let the hardware take care of everything.
Another option?
You will have to buy me a beer first
Unfortunately, even if I just have the ISR do a variable++ and read it out in the code, I only appear to be getting 6 IRQs. I tried reading all 11 bits inside the ISR but I think I don’t understand enough about what I’m doing yet; this is my first foray into the world of hardware programming (I’m a C# web applications developer by trade). I will continue to read and poke and hopefully not burn myself with solder too much until I get it. If nothing else, it’s good fun, and I’m learning things I never knew about microprocessors!
Thanks again for all your help, it’s much appreciated - if I lived close enough, I would definitely be buying you beer!
