Prototyping board with Servo 3-pin connectors for FEZ Mini
Hello! FEZ Mini.
  1. I’m looking for board with several 3-pin servo connectors.
    Each signal must be connected to Mini Di0-Di10, A0-A7 pins. Power to +5V, GRD to GRD.
  2. Is there version of Mini without pin headers soldered?
    Can I unsolder pins from std version?
Thank u.
Why not plug it in a bread board and wire the servos any way you like?
Thank u for quick response!
I would like to install FEZ mini+sensors to RC car. I need to connect 2 servos and 2 RC channels to Mini. There is no space in car for beadboard. I would like to remove unused pins from Mini and connect in with Servo board and sensors via cabels.
P.S. i’m looking for something like that:
Parallax Power Input, 3-pin Header I / O Daughterboard
but without power and more 3-pin headers
From SeedStudio. I have used this. You can connect the servos directly.
Yes, I know it, but it for Domino not for Mini and big.
Then use those prototyping boards that have matrix of holes to create a board to the size you like
Ok, I don’t understand one thing.
First, it has to be small. Next, you say you need 2 servos on 2 RC channels.
And you also say
"Each signal must be connected to Mini Di0-Di10, A0-A7 pins. "
So, how many servos would you like and what is your space in the RC car?
Yes 2 servos, and 2 rc channels. Other 3-pin headers for sensors and for future use.
3 pin headers as in JST connectors or as in servo connectors?
JST:
http://www.tinyclr.com/hardware/12/fez-cobra/#/grid/item/111/
servo connectors
um your gonna have to make one. Already lost on me what your even trying to do here.
Same here ???
OK, will this work?
[url]Arduino Nano IO Sensor Shield -DFRobot
