Do you take into consideration ESD when you design Gadgeteer modules and mainboards? I have seen only one product made by GHI that is using TVS diodes for USB interface protection, apart from that it looks like there is no protection used.
I doubt that users are generally wearing wrist straps when they are dealing with Gadgeteer products.
Also, there are different ESD ratings, some ICs offer, for example, 2kV protection for all of their pins but suggest using additional protection if pins could be externally accessible.
I am in a process of creating a new Gadgeteer module, so I would appreciate any advises, insights, guidelines etc.
The first board we 've designed was based on EMX. We didn’t care so much about ESD. Board controls some relays, it uses USB, ETH, Anolog and digital IO’s, One Wire… The major problem was concerning USB. Most of the time USB CDC was failing when a relay switches. The problem was that this was unrecoverable unless rebooting the EMX. We decided to use TVS diode from Wurth Electronik a ferrite from the same company according to their design rules without any success… Thus we don’t use USB CDC anymore
Now the board is based G400, I still add TVS diode and a ferrite on USB even if it is not used, and I have added clamp diodes and a PTC fuse on each analog IO’s.
When we talk about end users yes everything is possible. However I have only observed failures and damaged devices due to bad wiring, shortcuts… To my opinion none of damaged devices was due to ESD ( may be one or two (see picture of metal case) in 3 years and an hundred of devices in the field).
It would be good to have GHI design tips to handle ESD and bad wiring.
I have try to test the clamp diode and a fuse but I didn’t see anything usefull, the zener seems not regulate at 3.3V and I can apply what I want on channel, nothing happens… :’(
